Bing Maps has stopped working
savski
by savski » Wed Apr 16, 2014 5:05 am
Hi all,
I recently built a tour using Panotour Pro 1.8, which worked fine, but when I added a Bing map it wouldn't show the map, just a blank area where the map should be. I then looked back at a past virtual tour that did once work and this also showed a blank area (See below for this example). Does anybody know why this is happening and how I can fix it?? Many thanks in advance.
http://www.caritas-zuerich.ch/virtuelle ... rthur.html
Liked in: 226 posts
Re: Bing Maps has stopped working
by Destiny » Wed Apr 16, 2014 5:23 am
Hi... I think you will find that you need a new API code for BING and Google Maps.. The old codes do not work..
Likes: 13 posts
Liked in: 112 posts
by bdd » Wed Apr 16, 2014 8:56 am
savski wrote:Hi all,
I checked the code of this tour, and found that you did not set a Bing Maps key for the Bing map layer.
You used your own PTP license key, not a Bing maps one.
