Corkscrew intro
farkinoff
Corkscrew intro
by farkinoff » Tue Apr 01, 2014 1:48 pm
Trying to figure out how to do the corkscrew intro in some of Sam's tours. The start parameters only show Autotour or auto rotate. I like how from the little planet start the tour corkscrews in then does one full (fast) spin and stops where he wants to. I feel dumb, I am sure there is something simple I am missing just can figure it out. Here is the link to Sam's sample.
http://www.samrohn.com/360-panorama/cen ... york-city/
Re: Corkscrew intro
by klausesser » Tue Apr 01, 2014 2:05 pm
farkinoff wrote:Trying to figure out how to do the corkscrew intro in some of Sam's tours. The start parameters only show Autotour or auto rotate. I like how from the little planet start the tour corkscrews in then does one full (fast) spin and stops where he wants to. I feel dumb, I am sure there is something simple I am missing just can figure it out. Here is the link to Sam's sample.
Hi!
You just need to edit the xml - setting a high value between start- and end of the move. When you set a highvalue it makes a full or more turn while moving
to the horizontal view.
Here i used a short turn: http://360impressions.de/ChinesenPlanet/
I did it years ago with PTP 1.8 (i guess).
The values in the basic xml:
</action>
<action name="setlittleplanet">
set(view.stereographic, true);
set(view.fisheye , 1.0);
set(view.limitview , lookat);
set(view.vlookatmin , -90);
set(view.vlookatmax , 90);
set(view.fov , 150);
set(view.fovmax , 150);
set(view.hlookat , 0);
set(view.vlookat , 90);
set(display.flash10 , off);
set(display.details , 14);
</action>
and the values in the xx0.xml:
<action name="tweennormalview">
tween(view.hlookat, 72, 8, easeInOutQuad);
tween(view.vlookat, -1.22, 8, easeInOutQuad);
tween(view.fov , 90, 8, easeInOutQuad );
tween(view.maxpixelzoom,1.0, 8, easeInOutQuad );
tween(view.fisheye, 0.0, 8, easeInOutQuad, WAIT);
set(display.flash10, on);
set(view.limitview , range);
set(view.vlookatmin, -90);
set(view.vlookatmax, 90);
set(view.hlookatmin, -180);
set(view.hlookatmax, 180);
set(view.maxpixelzoom, 1.0);
set(view.fovmax , 90);
</action>
farkinoff
Re: Corkscrew intro
by farkinoff » Tue Apr 01, 2014 2:17 pm
Thank you very much for the prompt response Klaus, was hoping it was not an xml edit but not a big deal. Again, thank you!
ERR
Likes: 4 posts
Liked in: 23 posts
Re: Corkscrew intro
by ERR » Tue May 27, 2014 6:39 pm
Klaus,
Your lack of distortion on rotation is amazing. I am assuming that is you "tweaking" out the pan to achieve this. Any tips on lowering edge rotation distortion?
Ed
The sun will come out, tomorrow... Well if not tomorrow then at least in 4 years and if not 4 years then most definitely 8 years max. But hopefully in 1 year or less.
Re: Corkscrew intro
by klausesser » Tue May 27, 2014 9:10 pm
ERR wrote:Klaus,
Ed
Hi Ed!
Just use no more than 90° - better 70° hor for the rotation.
