PopUp List in 1.8
marbotrade
PopUp List in 1.8
by marbotrade » Wed Mar 26, 2014 7:43 pm
Here is a VT.
http://www.360tour.ro//lib/flash/tur-vi ... arden.html
My question is:
In Panotour 1.8 how can make the PopUp List as in these Virtual Toir
HOTEL Restaurant & CAMERE FACILITATI
Bar
In version 2 I understand that it is possible, but in 1.8?
Tks,
Re: PopUp List in 1.8
by mediavets » Wed Mar 26, 2014 7:58 pm
marbotrade wrote:Hi,
Here is a VT.
My question is:
Bar
Tks,
Not via the GUI.
You could not replicate that precisely in PTP 2.x via the GUI either.
Welcome to the forum....
marbotrade
by marbotrade » Wed Mar 26, 2014 8:32 pm
Thank you,
But I don't understand. In this case, KRPANO is better then Panotour?
by mediavets » Wed Mar 26, 2014 8:53 pm
marbotrade wrote:Thank you,
The krpano Flash and HTML5 Panorama Viewers are 'driven' by command files, for which you will find the documentation here:
http://krpano.com/docu/
Panotour and Panotour Pro (PT/PTP) are essentially GUI front-end command file generators for the krpano Flash and HTML5 Panorama Viewers which make it far easier to create tours than having to hand code from scratch.
PT/PTP do not allow you to create every effect via their GUI that you could if you were to hand code.
