Can this be done with Panotour Pro?
senya
by senya » Sun Mar 23, 2014 1:41 am
Hi there,
I'm new to this software, but I have seen what it can do, now before I go ahead and make a purchase I have a question.
I would like to use Panotour Pro for virtual real estate and business tours, but I want to have a bit of a custom design to my tours, unless it's already available by default without any customization.
I would like to have a tour that I can embed into a website, tour must have the following, here is a description:
Tour window
1. Side bar on the left with a list of panoramas included in a particular tour.
2. Panorama in the center of the window.
3. Side bar on the right, that will contain area map and some information about the tour, or contact information.
I hope I explained this well, if not I can maybe do a quick sketch of the look that I'm trying to get.
Please let me know how hard is this to achieve? If someone already knows how or has an example would really appreciate to see it.
Thank You
Senya
Re: Can this be done with Panotour Pro?
by mediavets » Sun Mar 23, 2014 8:16 am
senya wrote:I would like to have a tour that I can embed into a website, tour must have the following, here is a description:
Tour window
Thank You
Senya
Welcome to the forum...
You can create tours with these features - without custom coding - but perhaps not precisely your desired 'look'.
It would help if you could provide that quick sketch of what you envisage.
senya
by senya » Sun Mar 23, 2014 3:57 pm
Thank you for your comment.
I did a quick sketch of the layout I'm looking for.
Here is what I also would like to do with it:
1. I want the side bars that are used for list of panos and a map to be able to open and close.
2. Have 2 separate side bars on the right that will be able to display an interactive map and information on another side bar. Be able to switch between them by pressing on info and map tabs.
How hard is it to achieve something like these?
Senya
by mediavets » Sun Mar 23, 2014 5:53 pm
senya wrote:Thank you for your comment.
Senya
Relatively easy .... but without the Tabs; PTP doesn't offer tabs like those as a standard feature.
by mediavets » Sun Mar 23, 2014 7:12 pm
Here is a quick mock up for you.
Is this something like what you had in mind?
