Convert tour project from AutoPanoTour to Panotour. Howto?
MichaelG
by MichaelG » Wed Mar 19, 2014 7:04 pm
Good day!
Is there any method to convert tour project from AutoPanoTour .apt to Panotour .kpt ?
I want to remaster some of my old tours using new Panotour.
Any advise will be apretiated : )
Liked in: 129 posts
Re: Convert tour project from AutoPanoTour to Panotour. Howt
by mediavets » Wed Mar 19, 2014 7:41 pm
MichaelG wrote:Good day!
Any advise will be appreciated : )
If the tours are quite small - not to many scenes - then I would suggest you start over in PTP 2.x.
PTP 1.8 can read .apt files - but I don't recall how much functionality is retained - then you could save as .kpt.
PTP 2.x can open .kpt files from PTP 1.8 but only limited functionality is imported.
MichaelG
by MichaelG » Wed Mar 19, 2014 7:54 pm
mediavets wrote:If the tours are quite small - not to many scenes - then I would suggest you start over in PTP 2.x.
Thank you for the advice! I'll try 1.8-2.x converter aproach
