Non-rotating tour w/hotspot overlays
BobF
by BobF » Wed Mar 19, 2014 3:00 pm
I want to do a non-rotating type of tour. What I'd like to do is stitch a pano (or use a fisheye lens) then add a number of hotspots which will link to other images and have those images appear on top of the pano when a hotspot is clicked. So the pano/fisheye image would be used as a wide angle perspective and the hotspots would then drill down to images of smaller, more detailed areas. Is this possible with PTP?
Thanks.
Re: Non-rotating tour w/hotspot overlays
by mediavets » Wed Mar 19, 2014 4:10 pm
BobF wrote:I want to do a non-rotating type of tour. What I'd like to do is stitch a pano (or use a fisheye lens) then add a number of hotspots which will link to other images and have those images appear on top of the pano when a hotspot is clicked. So the pano/fisheye image would be used as a wide angle perspective and the hotspots would then drill down to images of smaller, more detailed areas. Is this possible with PTP?
Thanks.
Yes.
Are you still using PTP 1.8?
BobF
by BobF » Wed Mar 19, 2014 4:26 pm
I am.
BobF
by BobF » Fri Mar 21, 2014 6:30 pm
Any hints on how best to go about it?
