"Map" and "Sharing The Tour" buttons won't work
Blue Maple
by Blue Maple » Wed Mar 12, 2014 12:25 am
I built my first tour. Nothing special, just a test to see how everything works.
I can not get the "Map" and "Sharing The Tour" buttons to work. They work fine when I view the last tour built in Panotour Pro 2.0.
http://www.bluemaplepanotours.com/
Any suggestions?
Brian
Re: "Map" and "Sharing The Tour" buttons won't work
by mediavets » Wed Mar 12, 2014 12:45 am
Blue Maple wrote:I built my first tour. Nothing special, just a test to see how everything works.
Any suggestions?
Brian
Did you upload the entire contents of the folder into which you built the tour maintaining the file and folder structure?
Blue Maple
by Blue Maple » Wed Mar 12, 2014 2:01 am
Yes, I use the direct FTP loader in PTP to send the files to my web host server.
Maybe I need to manually FTP them?????
Blue Maple
by Blue Maple » Wed Mar 12, 2014 2:19 am
Blue Maple wrote:Yes, I use the direct FTP loader in PTP to send the files to my web host server.
That worked, the FTP loader in PTP 2.0 does not load all the files. It is best to manually do it.
