Embed size
Re: Embed size
by mediavets » Wed Feb 26, 2014 11:23 pm
edgar_ali wrote:I have just realised that If I click on http://flash.imaginephotographs.com.au/ ... room2.html it open the tour filling the whole browser...
that is interesting
I would like to understand why is that
Because it's not in an iframe on a Wordpress site and you specified a fullscreen HTML template in PTP 2.x Build options I guess?
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 11:31 pm
Mate:
Thanks a lot!!
Now I'm going for the second part:
If I want to embed this tour: http://flash.imaginephotographs.com.au/ ... /room2.htm In another website, what do I need to do so the other website embed this tour only...
Because what is happening now is that when I try to embe the tour in squarespace..it embed the whole wordpress site..
Have a look here: http://www.imaginephotographs.com.au/virtual-tours-1/
I have to use the scroll bars to see the tour...I don't want to do that
Do you know what I mean?
Re: Embed size
by mediavets » Wed Feb 26, 2014 11:50 pm
edgar_ali wrote:Mate:
Thanks a lot!!
Perhaps this will help:
http://screencast.com/t/uaLDjbE40
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Thu Feb 27, 2014 12:11 am
This is the code that i used:
<iframe src="http://flash.imaginephotographs.com.au/test" frameborder='0' width='100%" height='1000px' allowFullScreen></iframe>
and this is what I got:
http://www.imaginephotographs.com.au/virtual-tours-1-2/
Is there something that I'm not doing right?
Re: Embed size
by mediavets » Thu Feb 27, 2014 10:26 am
edgar_ali wrote:This is the code that i used:
Your iframe code is interacting with SquareSpace template CSS I think.
In any case you cannot specify width in an iframe as a %. Height and width can only be specified in pixels.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Mon Mar 03, 2014 12:46 am
YOu are certainly right...
Squarespace have suggested to use the following link for support:
http://stackoverflow.com/questions/1008 ... rom-iframe
In this link they explain that I should type this in my CSS:
iframe{
overflow:hidden;
In that forum they mention that the horizontal scroll still shows after typing the above code so they suggest to type:
iframe{
overflow-x:hidden;
My first question is:
Do i need to type both the above codes or just one?...if it is just one, then which?
They also say that I should type this:
<div id="myInfoDiv" seamless="seamless" scrolling="no" style="width:100%; height: 100%; float: left; color: #FFF; background:#ed8719; line-height:100%; font-size:100%; font-family: sans-serif>;
In the above code, what I am suppoused to type in "myInfoDiv" ??? . I'm also guessing that this code is not CSS, this go in the same section as the iframe, is that right?
Second: Do i need to type the above code before, after or within the following code:
<iframe src="http://flash.imaginephotographs.com.au/test" frameborder='0' width="800" height="600" allowFullScreen></iframe>
The person who initially asked the question in the iframe forum typed the following code:
<iframe frameborder="0" style="height: 185px; overflow:scroll; width: 100%" src="http://www.cbox.ws/box/?boxid=439&boxtag=7868&sec=main" marginheight="1" marginwidth="1" name="cboxmain" id="cboxmain" seamless="seamless" scrolling="no" frameborder="0" allowtransparency="true"></iframe>
In the above code, what is name= cboxmain and id=cboxmain...
If I had to use that code, what should i write there?
If you can provide any assistant, it will be greatly appreciate it.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Tue Mar 04, 2014 3:37 am
I have finally get to a reasonable solution...
I use a link which contain the tour in full screen : http://flash.imaginephotographs.com.au/ ... room2.html
Instead of using the previous link: http://flash.imaginephotographs.com.au/test/
I also modify the height and the width, resulting in the following code:
<iframe frameborder="0" style="height:650px; overflow:visible; width:720px" src="http://flash.imaginephotographs.com.au/wp-content/uploads/room2.html" marginheight="0" marginwidth="0" "seamless="seamless" scrolling="no" frameborder="0" allowtransparency="true"></iframe>
Previous
