Embed size
edgar_ali
Liked in: 3 posts
Embed size
by edgar_ali » Fri Feb 21, 2014 4:32 am
I am currently using Panotour Pro 2.0 . I have created a tour (a dummy) and uploaded in:
http://flash.imaginephotographs.com.au/?page_id=10
As you can see in that page, the tour is display as a little square. I have change the width and height properties in the panopress link and settings (as you can see in the pictures below:
embedding in wordpress.JPG (25.78 KiB) Viewed 3664 times
As you can see in: http://flash.imaginephotographs.com.au/?page_id=10 the panorama is display as a rectangle, eventhough I have established in the settings a width and a height of 700px
Why is that?... how can I display my panorama as a square (700 x 700 px ) instead of a rectangle as it is now?
My second question is:
I have uploaded my panorama here: http://flash.imaginephotographs.com.au/?page_id=10
However I want to embed this panorama in: http://imaginephotographs.squarespace.c ... l-tours-1/
When I embed the panorama into this website, it display the whole website instead of the panorama.
The code that I’m using to embed this panorama into the website is:
<iframe src="http://flash.imaginephotographs.com.au/?page_id=10" width="800" height="600" allowFullScreen></iframe>
I would like my panorama to looks like this example:
http://imaginephotographs.squarespace.c ... ual-tours/ (be aware that I took this example from http://www.aircamera.fr (I will remove this tour after I understand what I need to do to show my tour as this)
If I launch the tour online using chrome, this is how it looks:
http://www.screencast.com/t/jxmMeTjQ6D
Please let me know if you need more info to help me
Re: Embed size
by mediavets » Fri Feb 21, 2014 10:23 am
Use an iframe rather than the Panopress plugin.
The iframe should reference the HTML file created by PTP 2.x when you build the tour.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Mon Feb 24, 2014 6:14 am
The only problem is that as you can see in my directory there is no a HTML file..i've got SWF and XML
Refer to this link for the picture of my directory: http://www.screencast.com/t/ScRy69nP
What can I do then?
Re: Embed size
by mediavets » Mon Feb 24, 2014 10:47 am
edgar_ali wrote:The only problem is that as you can see in my directory there is no a HTML file..i've got SWF and XML
What can I do then?
The HTML file will be one level up in the directory tree.
I suggest you configure your system to display file extensions too.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Mon Feb 24, 2014 11:45 pm
I am going to recheck this..but all i did was copy the whole folder that panotour created in my computer...when do you say : level up in the directory tree, does it means that that file is out of the folder that panotour created?
Re: Embed size
by mediavets » Tue Feb 25, 2014 11:12 am
edgar_ali wrote:I am going to recheck this..but all i did was copy the whole folder that panotour created in my computer...when do you say : level up in the directory tree, does it means that that file is out of the folder that panotour created?
When you Build a tour into a new folder the file/folder structure looks like this:
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Tue Feb 25, 2014 11:25 pm
you were right I found the HTML file...now, how can I use iframe?...sorry for all this basic questions...I'm still on the learning curve
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Tue Feb 25, 2014 11:27 pm
before you answer my question...I'm gonna have a go using this:
<iframe width="800" height="600" src="http://www.yourdomain/your-tour-folder/your-tour.html" allowfullscreen></iframe>
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 12:08 am
I'm using this Iframe code:
<iframe src="http://WWW.MY-DOMAIN.COM/VIRTUAL_TOUR/MY-TOUR.html" width="800" height="600" allowFullScreen></iframe>,
which I substituted for:
<iframe src="http://flash.imaginephotographs.com.au/room2data/room2.html" width="800" height="600" allowFullScreen></iframe>
However I dont know if I'm not writing the proper path to the file or I need to do something else in wordpress that I'm missing, since I am just getting a blank page with the wording of the code
The path where my HTML file and the panotour folder are located in my website according to my ftp manager is:
/public_html/flash/wp-content/uploads
Please help
Re: Embed size
by mediavets » Wed Feb 26, 2014 12:26 am
The URL you specified http://flash.imaginephotographs.com.au/ ... room2.html is invalid.
The URL you specify in the iframe should be a viable URL to the tour.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 12:30 am
I have just changed it to the following URL, but still not working:
<iframe src="http://http://flash.imaginephotographs.com.au/?page_id=28/room2.html" width="800" height="600" allowFullScreen></iframe>
What can I do?
Re: Embed size
by mediavets » Wed Feb 26, 2014 12:31 am
edgar_ali wrote:I have just changed it to the following URL, but still not working:
What can I do?
What is the URL from which you can view the tour - before you try and embed it in Wordpress?
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 12:35 am
this one:
I have removed the iframe code and just typed test
Re: Embed size
by mediavets » Wed Feb 26, 2014 12:59 am
edgar_ali wrote:this one:
No, no, no.
I want to know the URL of the HTML page associated with the tour. That's what need to go in the iframe.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 1:31 am
maybe I've got a confusion here...
at the begining of my post I was trying to explain that I first uploaded a tour on wordpress and then I was trying to embed this tour in a different site....
Right now What I would like to do is just upload a tour in wordpress using iframe or something else...What I really want now is that the tour take the whole space of the page and that is why I chose a template (background only) so the tour could take all the space as in: http://www.aircamera.fr/visite_virtuell ... s/360.html
After I have achieved that, then I would like to embed my tour in a different site...
My current problem is that I have not been able to upload the tour in wordpress, let alone embed it in a different site...
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 2:31 am
any idea?...please I need help
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 6:04 am
I finally made it appear on the website...i used the following code:
<div style="text-align:center;">
<iframe src="http://flash.imaginephotographs.com.au/wp-content/uploads/room2.html" height="900" width="1440" allowfullscreen=""></iframe>
</div>
Now i just want the bloody thing to fill the whole page...how can I do that?....
I entered a width of 1440 and height of 900...but I haven't been able to centre the tour.How can I centre and fill the whole page at the same time?
Re: Embed size
by mediavets » Wed Feb 26, 2014 10:26 am
edgar_ali wrote:I finally made it appear on the website...i used the following code:
</div>
What is the URL to your tour on Wordpress?
I had a look at your 'tour' - http://flash.imaginephotographs.com.au/ ... room2.html
You appear to have a proper pano head but what a mess ...what camera and lens are you using and what shooting pattern?
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 10:46 pm
I took that picture without setting the no parallax point (nodal point, whatever people want to call it)..that is the reason for such a mess...also I just took it quickly since I just want to understand how to set it properly in the website...
How can I fill the whole page with the tour?...if i change the width and height in the "iframe", it increase the size of the tour but place it aligned to the right, not allowing to see the full tour...how can I increase the size to fill the whole page and that everything is centered?..
I would like my tour to looks like: http://www.aircamera.fr/visite_virtuell ... s/360.html as you can see in this page, this tour fill the whole page.
Re: Embed size
by mediavets » Wed Feb 26, 2014 10:49 pm
edgar_ali wrote:I took that picture without setting the no parallax point (nodal point, whatever people want to call it)..that is the reason for such a mess...also I just took it quickly since I just want to understand how to set it properly in the website...
That URL is dysfunctional - bits missing.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 10:59 pm
yes I just realised that URL is not working...
anyway I guess my point is: how can I fill the whole screen of the web browser (not the whole monitor) with my tour...
How can I do that?
Re: Embed size
by mediavets » Wed Feb 26, 2014 11:09 pm
edgar_ali wrote:yes I just realised that URL is not working...
How can I do that?
If I could view that URL I might be able to offer a suggestion.
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 11:13 pm
Since I'm a newbie in this...I find hard to understand which url you want...
Let me have a go:
The url of the tour is:
http://flash.imaginephotographs.com.au/test/
If you need the address that I used in the iframe:
Otherwise I'm not really sure which url you want..if these are not the correct, please help me to understand this...sorry for taking this long...thanks for your patience
edgar_ali
Liked in: 3 posts
Re: Embed size
by edgar_ali » Wed Feb 26, 2014 11:18 pm
I have just realised that If I click on http://flash.imaginephotographs.com.au/ ... room2.html it open the tour filling the whole browser...
that is interesting
I would like to understand why is that
Re: Embed size
by mediavets » Wed Feb 26, 2014 11:21 pm
edgar_ali wrote:Since I'm a newbie in this...I find hard to understand which url you want...
Let me have a go:
Well I really wanted to see the aircamera.fr tour that you wanted to emulate.
But seeing your embedded tour it's plain the the Wordpress theme (css) determines where on the page your iframe is displayed.
You can only speciify the size of an iframe in pixels not as %.
So I don't think you can do exactly what you would like within a Wordpress site.
But the user has the option of going to fullscreen (and back) via the control bar.
