Outside links into tours
ssaccio
by ssaccio » Tue Feb 04, 2014 1:54 am
Sorry if this has been talked before but I need a quick answer for a client and couldn't find it with a brief search.
I have an 11 spin tour made. Per norm It opens on the first spin with thumbnails at the bottom to link and view the other 10. The web developer I'm working with though wants hyper links from off the tour to go to specific different spins in the tour. Is this possible?
I know how to embed a map in the tour but they want it to be completely separate so they can change out information without rebuilding the tour each time.
Thanks for any advice you can provide!
Re: Outside links into tours
by mediavets » Tue Feb 04, 2014 9:40 am
ssaccio wrote:Sorry if this has been talked before but I need a quick answer for a client and couldn't find it with a brief search.
Welcome to the forum...
Difficult with PTP 1.8 - you'd need to integrate a third party plugin:
http://krpano.com/plugins/userplugins/swfaddress/#top
But easy with PTP 2.x:
http://www.autopano.net/wiki-en/action/ ... ur_Pro_.3F
ssaccio
by ssaccio » Tue Feb 11, 2014 7:29 pm
Perfect! thanks for the link.
And convient timing for 2.0 to be released!
