Import tour into pdf or powerpoint?
Chuck Person
by Chuck Person » Sat Jan 25, 2014 7:28 pm
Is it possible to import the .swf tour into a pdf file or a powerpoint presentation, and if so do you have a link to the directions on how to do it? Thanks
Re: Import tour into pdf or powerpoint?
by mediavets » Sat Jan 25, 2014 7:58 pm
Chuck Person wrote:Is it possible to import the .swf tour into a pdf file or a powerpoint presentation, and if so do you have a link to the directions on how to do it? Thanks
Don't know if this will do it - for PowerPoint - but it might:
http://www.globfx.com/products/showroom/
by mediavets » Sat Jan 25, 2014 10:26 pm
Likes: 3 posts
Liked in: 226 posts
by Destiny » Sat Jan 25, 2014 11:10 pm
You need to embed all data in your V1.8 Tour and then you can add your pano into a PDF via an object. But, you need to make sure its a small file size, small pano images or it will not run very nice.. Remove zoom/layers which will help heaps... Remove +/- on your menu too....
