A Problem with Android devices
JBel
by JBel » Mon Jan 20, 2014 9:02 pm
Hi, i'm using Panotour 1.8 to build my virtual tours. i succeeded to play them on iPad and iPod, but i don't on Android devices!
i tried to load my virtual tours on many Android devices (like Galaxy) but it didn't succeeded!!
anyone have any idea about this problem?? :(
thanks in advanced.
Re: A Problem with Android devices
by mediavets » Mon Jan 20, 2014 9:09 pm
JBel wrote:Hi, i'm using Panotour 1.8 to build my virtual tours. i succeeded to play them on iPad and iPod, but i don't on Android devices!
thanks in advanced.
The only mobile platforms supported by PTP 1.8 are Apple iDevices.
You need to upgrade to PTP 2.x for Android support.
HansKeesom
by HansKeesom » Mon Jan 20, 2014 11:58 pm
thanks in advanced.
Fortunate it should not be to hard converting 1.8 projects to 2.0 projects. I have tried to do a few and it looked ok.
Links are saved, just need to apply a style. As long as no coding is done, it looks doable.
JBel
by JBel » Tue Jan 21, 2014 12:16 am
thanks in advanced.
what do u mean?? and what had u exactly tried to do??
HansKeesom
by HansKeesom » Tue Jan 21, 2014 1:19 am
Loaded an old project into 2.0, choose a style and generated the tour with 2.0 into a html5 tour with multires.
Nothing complicated like moving from
1.8 http://alsofjeerbent.nl/panoramas/Dunske/
to
2.0 http://alsofjeerbent.nl/panoramas/DunskeMultires/
Took less then half an hour including the uploading.
Regards, Hans Keesom
JBel
by JBel » Tue Jan 21, 2014 11:11 am
thanks in advanced.
First of all, thanks a lot for the answer, but i wanna be sure if Panotour Pro 2.0 support Android?! i have to be sure before i buy it!
thank you so much in advanced :)
JBel
by JBel » Tue Jan 21, 2014 11:15 am
to
really thank you so much :)
a lot thanks for u :)
HansKeesom
by HansKeesom » Tue Jan 21, 2014 12:33 pm
to
You are welcome! I can't quarantee every 1.8 tour will work on 2.0 that easy. But I have the feeling that if you did not do any coding or special plugin work, it should work really easy. Maybe send me a pm to discuss this a bit further and also about ways I might be able to help you in this.
