hotspot tooltip info text only 1 line possible?
mischimei
by mischimei » Tue Jan 14, 2014 5:40 pm
Hi there,
does anybody know how to customize the 1 line tooltip preset on hotspots?
I have a few info texts that are longer and would like them to appear
in 2 or three lines rather than 1 line across the entire screen.
Ideally I would like the lines to appear
centered in the middle of the tooltip down rather than flush right.
I am using panotour pro 1.8.
Thanks a lot.
Re: hotspot tooltip info text only 1 line possible?
by mediavets » Tue Jan 14, 2014 6:02 pm
Welcome to the forum...
It can be done, I've just forgotten how.
Hopefully someone else will remember.
mischimei
by mischimei » Tue Jan 14, 2014 7:01 pm
thanks for your swift reply mediavets,
yes, I really hope so too,because this 1 line preset
doesn't work for me.
Thanks again.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Wed Jan 15, 2014 4:48 pm
To change the alignment I don't know, but you can add <br> when you want to move on to the next lign, that works in tooltips ..
So your tooltip would be:
This is my tooltip <br> And I just moved on to the next line.
And look like this:
This is my tooltip
mischimei
by mischimei » Wed Jan 15, 2014 8:40 pm
Hi Lmih,
yes thank you.that works fine.
the kolor team advised me to get version 2.0
because of all the added features.
thanks again.
