wordpress/panopress/info
Klaude
by Klaude » Sun Jan 05, 2014 5:36 pm
Hello
I need your expertise please...
My website is in wordpress and I installed the plugin 'panopress' which allows the visualization of virtual tour.
However I wonder if this virtual tour page is properly used.
On this page there are 3 virtual tours installed.
And when I look at this page 3 visits seem to be active at the same time ... I think that extending the loading time for the user.
Can you tell me if it is consistent? And how do I do that is seulevisite ACTIVEA time?
Here is the link: http://www.claudegagnon.com/?page_id=843
Thank you for your help is valuable to me ..
Greetings from Montreal (Canada) ..
Klaude
Re: wordpress/panopress/info
by mediavets » Sun Jan 05, 2014 7:10 pm
Well, yes, loading three tours at the same time on one web page will increase the load time for each.
What is your question exactly?
What is it you want us to tell you?
Klaude
by Klaude » Sun Jan 05, 2014 7:37 pm
Mediavets
Hello
Thank you for your help ...
I want to know how to present only a virtual tour at once ..
Or how to disable 2 visits only 1 is active.
Thank you again ...
by gkaefer » Mon Jan 06, 2014 12:18 pm
Klaude wrote:Mediavets
create screenshots from your panos you want to Display to your visitors.
use These screenshots for your index page.
using panopress it would be:
[pano file="marktschellenberg/marktschellenberg.swf" width="640" height="301" preview="marktschellenberg-klein.jpg"]
the ...swf file is your path to your pano (I choose the SWF Version in my case)
the ...jpg is the path to my preview
result: http://www.gigapixel.at/?p=397
more configuration (in Special if you Focus on html5 too) options see: http://www.panopress.org/instructions/
Klaude
by Klaude » Tue Jan 07, 2014 8:26 pm
I will try your suggestion and keep you informed
Thank you very much for your help!
Aaron Eriksson
by Aaron Eriksson » Sun Jan 12, 2014 4:17 am
Hello. I crossed this bridge long ago. I picked a theme format that I liked and tweeked it. I use an Iframe sized in % within a page. The other tours are linked by thumbnails. Nice thing about the way wordpress works, I can put the active tour in my blog so when the viewer opens the blog the tour is live. I don't know why the panopress requires you to hit the play button. I wanted mine to go live once the page loads. I think this is the simplest solution but also the best.
