Blank page
rcpagan
Blank page
by rcpagan » Mon Dec 16, 2013 6:16 pm
I am getting a blank page when opening my virtual tour, this is the url for it:
http://distinx.com/vtour/lofts/virtual_ ... ltour.html
Using the developer console on firefox i found this error:
[11:52:52.769] ReferenceError: embedpano is not defined
any suggestions hoe to correct it?
thanks
Re: Blank page
by mediavets » Mon Dec 16, 2013 6:42 pm
rcpagan wrote:I am getting a blank page when opening my virtual tour, this is the url for it:
thanks
Welcome to the forum...
Is this HTML page as created by the HTML template when building the tour or have you modified it?
If its a standard HTML file created by PTP 1.8, are you sure you uploaded all the files created when the tour was built and maintained the file/folder sturcute?
Are you sure the file permissions are correct on the web server?
Which version of Firefox, with which OS, are you using to view the tour?
rcpagan
Re: Blank page
by rcpagan » Mon Dec 16, 2013 6:54 pm
The only thing i modified on the html was the text on header. I have switched back to to the original but no success. The folder file structure was kept intact. I have tried several different permissions, no change. What should the permissions be? Just to make sure i got it right. I can open the tour locally with no problems.
Firefox 25.0.1 / OS MAC OS X 10.9 Maverick, I have tried chrome and safari and even on windows machines and have the same issue, just a blank page.
I just rebuild the tour and will upload it with no modifications.
Thanks for the assistance.
Re: Blank page
by mediavets » Mon Dec 16, 2013 7:00 pm
rcpagan wrote:The only thing i modified on the html was the text on header. I have switched back to to the original but no success. The folder file structure was kept intact. I have tried several different permissions, no change. What should the permissions be? Just to make sure i got it right. I can open the tour locally with no problems.
What FTP program are you using to upload the tour.
Other Mac users have in the past reported that some Mac FTP programs set file permissions in correctly.
rcpagan
Re: Blank page
by rcpagan » Mon Dec 16, 2013 7:06 pm
FileZilla 3.6.0.2
rcpagan
Re: Blank page
What are the proper permissions?
Thanks a lot
Re: Blank page
by mediavets » Mon Dec 16, 2013 7:52 pm
rcpagan wrote:What are the proper permissions?
Thanks a lot
My PTP 1.8 tour XML files have these permissions:
rcpagan
Re: Blank page
by rcpagan » Mon Dec 16, 2013 11:07 pm
Thanks a lot, you guided me the right direction. The problem was related to the permissions. I was compressing the files before uploading, which must affect the permissions. I uploaded the files without compressing them and it works fine. Thanks again for your quick replies!
