Only visible on over
jeese
by jeese » Sun Dec 15, 2013 5:10 pm
Hello. I'm trying panotour pro 1.8.
I would like to make a hotspot visible only when the mouse is hovering it.
If I click the option "Only visible on over " it doesn't work.
I've tried with all sort of hotspot. The image I try to display is always visible.
Am I doing something wrong ? Or is it because I'm using a trial version ?
I had a look at panotour pro 2.x this option doesn't seems to be available anymore. Is it ?
Thanks for any help.
Re: Only visible on over
by mediavets » Sun Dec 15, 2013 7:11 pm
jeese wrote:Hello. I'm trying panotour pro 1.8.
PTP 1.8 32-bit or 64-bit on which OS?
Which browser are you using to view the tour?
Yes, see screenshot below:
by mediavets » Sun Dec 15, 2013 7:23 pm
If I click the option "Only visible on over " it doesn't work. .
It is working for me with Windows XP/32 viewing with Firefox 25.
jeese
by jeese » Sun Dec 15, 2013 7:30 pm
Thanks.
I'm using PTP 1.8 32-bit on windows 7 64bits, and google chrome to watch the tour. (I've tried with internet explorer to. Firefox doesn't open it.)
jeese
by jeese » Sun Dec 15, 2013 7:46 pm
Firefox now opens the tour (I didn't have the flash player). Still doesn't work when I make it with PTP 1.8 but it works with PTP 2.0 64 bits...
Better than nothing. Thanks
by mediavets » Sun Dec 15, 2013 8:54 pm
jeese wrote:Firefox now opens the tour (I didn't have the flash player). Still doesn't work when I make it with PTP 1.8 but it works with PTP 2.0 64 bits...
Perhaps the problem was your using 32-bit PTP 1.8 on 64-bit Windows 7?
jeese
by jeese » Mon Dec 16, 2013 11:41 am
I've tried PTP 1.8 64 bits. Still the same problem. But actually, it works with polygonal hotspot but not with image hotspot.
Maybe it's not made to work with this kind of hotspot, in PTP 2.0 the option is not available. (or maybe I didn' see it.)
by mediavets » Mon Dec 16, 2013 11:49 am
jeese wrote:I've tried PTP 1.8 64 bits. Still the same problem. But actually, it works with polygonal hotspot but not with image hotspot.
It's only available with Polygon hotspots in both 1.8 and 2.x.
The screenshot in my previous post shows the option in PTP 2.x:
viewtopic.php?f=33&t=20832&p=133133#p133080
jeese
by jeese » Mon Dec 16, 2013 12:58 pm
Ok. thanks for your answers.
I thought it was possible to make it with images hotspot to, cause there is the option "Only visible on over " on PTP 1.8. But it's true that the option no longer appear when I select an object (image).
