Virtual tour flash problem android 4.2.2
pitigarcia
by pitigarcia » Sat Nov 23, 2013 11:16 am
There is some fix to can see a virtual tours in mobile with android 4.2.2?
Thanks in advance
Re: Virtual tour flash problem android 4.2.2
by mediavets » Sat Nov 23, 2013 11:24 am
pitigarcia wrote:There is some fix to can see a virtual tours in mobile with android 4.2.2?
Thanks in advance
The best solution is to upgrade to PTP 2.x which offers much wider support for mobile devices.
Alternatively you can experiment with updating krpano in the tours created with PTP 1.
See: http://krpano.com/tools/kupdate/
Or you could export your krpano licenses from PTP 1.8 and using the latest versions use krpano toolls droplets to create simple tours that should work on many Android devices.
