Problems embedding pano into webpage
andy4nothin
by andy4nothin » Sat Nov 09, 2013 5:46 pm
Just registered version 1.8 upon realising that I couldn't use the trial version on a live website.
I've gone from seeing the black flashplayer window with 'Error: Panotour Pro Trial', to a black flashplayer window informing me of the Panotour version, build, flashplayer version, registered to email, a warning and error.
The warning is: 'unknown action: hidepanospotsaction'
The error is: decoding failed - virtualtourdata/virtualtour0/preview.jpg
The pano works from the original generated HTML or the SWF when dragged into the browser.
The error: decoding failed path is only partial, and on my developement machine, sits inside another folder, eg 127.0.0.1/www.domainname.co.uk/panos/virtualtourdata/virtualtour0/preview.jpg
I've tried variations on the relative path which all result in a totally black box.
Any suggestions would be most welcome.
andy4nothin
Re: Problems embedding pano into webpage
by andy4nothin » Sat Nov 09, 2013 9:39 pm
Since there were no suggestions, I guess this was a basic newb error.
My consclusion is that it appears that the krpano viewer will only access jpgs from within its own directory and subdirectories. I think the structure of my URL's makes the viewer flash file think it's in a different location to the image directories.
My workaround is to use an iframe. To avoid creating an HTML file for each iframe/pano, I just create an index file with an include that points to the actual iframe HTML file and pass a variable in the URL.
Here's my first effort working: http://www.uktripper.co.uk/visits.cfm/kinver-edge/
There seems to be a problem with a corrupt cached image though. Otherwise, pretty pleased.
Any critique is welcome.
edgar_ali
Liked in: 3 posts
by edgar_ali » Wed Jan 22, 2014 12:01 am
I have created a simple tour using Panatour 1.8.
I opened the tour using my safari browser and I was able to see it.
I uploaded my tour to the following address and there is nothing:
http://www.screencast.com/t/rch1xOZkjvz
When uploading in a different host, I get the following message:
http://www.screencast.com/t/wnx139q1fXM
It says something about error: download of untitleddata... (check the screenshot attached above)
How Can I fix this problen so I can see my tour
by mediavets » Wed Jan 22, 2014 12:10 am
edgar_ali wrote:I have created a simple tour using Panatour 1.8.
Please don't duplicate post.
See: viewtopic.php?f=33&t=18371&p=135611#p135611
