Johnytuono wrote:Hi
I've done a search and found some code to put in the Hotspot link via the HTML option to open a text box when clicking a hotspot but I'm obviously doing something wrong. Where should I put the textfield plug-in for a start and am I putting the code in the right place (should it be in the html link or in the xml file?). If it's in the xml file, at what place should I insert it? As you can probably tell, I'm a real novice at this side of things, although I can usually (eventually) work my way round things but am struggling a little with this (I much prefer the GUI way).
Thank you for any help.
John
