Include virtual tour in PDF
florentd
by florentd » Tue Oct 22, 2013 8:17 am
i've created a virtual tour that all files can not be embeded in the swf. So it's more complex to include in a PDF file. For the moment i can not achieve to do this. I always get this error message: " FATAL: file//PDFMedia005666/g/0.xml - loading error (IO error)"
When i include the swf in the PDF document, i don't forget to add all ressources under properties menu, but doesn't works.
PDF swf.jpg (22.27 KiB) Viewed 1056 times
Re: Include virtual tour in PDF
by Destiny » Tue Oct 22, 2013 9:04 am
Hi.. You have posted this under PTP 1.8 so I am assuming you are using this version.. To get a pano to work in a PDF you need to embed all files.. You cannot use PTP V2 at the moment.. You also need to edit the size of your pano images to the minimum size and build your tour without a zoom to keep the file size down to the absolute minimum.. HTML 5 features will not work since they are related to the html code which is not compatible/supported with a PDF...
