code for direction of rotation of pano to spot view
macalenny
by macalenny » Tue Oct 08, 2013 6:55 am
What part of the xml code controls the direction of the rotation of the pano to spot (or spot to pano) view? (if selected when building).
Thanks!
This is the project I am working on, when you click hotspot for "downstairs" the initial rotation is opposite of the way I want it.
http://www.supremescene.com/miavac/florida/build.html
Re: code for direction of rotation of pano to spot view
by mediavets » Tue Oct 08, 2013 7:13 am
macalenny wrote:What part of the xml code controls the direction of the rotation of the pano to spot (or spot to pano) view? (if selected when building).
Thanks!
Dont know about the transition coding but I see an error mrssage when I view thw tour:
macalenny
by macalenny » Tue Oct 08, 2013 7:24 am
do you still see that?
thanks
by mediavets » Tue Oct 08, 2013 7:43 am
macalenny wrote:do you still see that?
thanks
Yes, I still see it when viewing from a different PC - so not just reading from browser cache.
Viewing with Firefox 24 on Windows XP 32-bit.
macalenny
by macalenny » Tue Oct 08, 2013 8:09 am
I had been getting that same error. Then I spaced the beginning of the code regarding the nadir in the xml file and then it had no error. I still do not see the error. firefox and chrome on mac.
If you have a chance please also check these links which is the same nadir graphic and code:
http://supremescene.com/miavac/neo/build.html
http://supremescene.com/miavac/treasure1/build.html
http://supremescene.com/miavac/sailaway1/build2.html
http://supremescene.com/miavac/castle-pool/build.html
http://supremescene.com/miavac/havana/build.html
by mediavets » Tue Oct 08, 2013 8:26 am
macalenny wrote:I had been getting that same error. Then I spaced the beginning of the code regarding the nadir in the xml file and then it had no error. I still do not see the error. firefox and chrome on mac.
No error messages when viewing those links.
macalenny
by macalenny » Tue Oct 08, 2013 8:32 am
thanks! error still on this one from the first post?
by mediavets » Tue Oct 08, 2013 8:55 am
macalenny wrote:thanks! error still on this one from the first post?
No error now when viewing from a third PC at a different location.
macalenny
by macalenny » Tue Oct 08, 2013 9:05 am
Much appreciated!
