hotspots on iPad
CCBain
hotspots on iPad
by CCBain » Thu Oct 03, 2013 9:57 pm
I'm finishing up a tour for a client, which is displaying well on desktops & laptops, but on my iPad (newest) the hotspots (swf) are not in their correct place. Just one hotspot appears per pano, floating in the upper left corner. The documentation mentions that "Flash (.swf) spots are replaced by default hotspot points (animated sequence). " Not sure why this is happening but I'm obviously missing some setting someplace. Can someone take a look at www.chrisbain.com/sppp/build/virtualtour.html
Thanks.
Likes: 13 posts
Liked in: 115 posts
Re: hotspots on iPad
by bdd » Fri Oct 04, 2013 9:31 am
This is strange, I looked at the code generated in your tour and do not saw what can create such bug.
But what can be done, is to "remove" the flash spot, and always use the alternative png animation that behaves the same way as your flash spot.
In the virtualtour0.xml file, find the following lines.
    <hotspot name="spot0" onclick="mainloadpano(virtualtour2.xml);" url="virtualtourdata/graphics/spots/spot0.swf" alturl="virtualtourdata/graphics/spots/spot1.png" altscale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" altonloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot0,0.1);" onhover="showtext(Visit Hempstead House entry driveway);" ath="-102.038" atv="-1.14894"/>
    <hotspot name="spot1" onclick="mainloadpano(virtualtour1.xml);" url="virtualtourdata/graphics/spots/spot0.swf" alturl="virtualtourdata/graphics/spots/spot1.png" altscale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" altonloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot1,0.1);" onhover="showtext(Visit the Hemstead House rose garden!);" ath="-70.059" atv="-2.69291"/>
    <hotspot name="spot2" onclick="mainloadpano(virtualtour3.xml);" url="virtualtourdata/graphics/spots/spot0.swf" alturl="virtualtourdata/graphics/spots/spot1.png" altscale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" altonloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot2,0.1);" onhover="showtext(Visit the Dejana Learning Center);" ath="72.9936" atv="0.382979"/>
    <hotspot name="spot3" onclick="mainloadpano(virtualtour6.xml);" url="virtualtourdata/graphics/spots/spot0.swf" alturl="virtualtourdata/graphics/spots/spot1.png" altscale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" altonloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot3,0.1);" onhover="showtext(Visit Castle Gould);" ath="33.3648" atv="-1.98425"/>
And replace them by the following lines :
    <hotspot name="spot0" onclick="mainloadpano(virtualtour2.xml);" url="virtualtourdata/graphics/spots/spot1.png" scale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" onloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot0,0.1);" onhover="showtext(Visit Hempstead House entry driveway);" ath="-102.038" atv="-1.14894"/>
    <hotspot name="spot1" onclick="mainloadpano(virtualtour1.xml);" url="virtualtourdata/graphics/spots/spot1.png" scale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" onloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot1,0.1);" onhover="showtext(Visit the Hemstead House rose garden!);" ath="-70.059" atv="-2.69291"/>
    <hotspot name="spot2" onclick="mainloadpano(virtualtour3.xml);" url="virtualtourdata/graphics/spots/spot1.png" scale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" onloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot2,0.1);" onhover="showtext(Visit the Dejana Learning Center);" ath="72.9936" atv="0.382979"/>
    <hotspot name="spot3" onclick="mainloadpano(virtualtour6.xml);" url="virtualtourdata/graphics/spots/spot1.png" scale="1.0" frame="0" lastframe="19" frameheight="64" framewidth="64" onloaded="set(crop,0|0|64|64);set(width,0);set(height,0);set(stopSequence,false);animate(spot3,0.1);" onhover="showtext(Visit Castle Gould);" ath="33.3648" atv="-1.98425"/>
CCBain
by CCBain » Thu Oct 10, 2013 8:15 pm
Thanks! One thing I can't figure out concerning the Hotspot Properties is why the choices vary. When I highlight a link between two panos, in the Display area, under Object, I get different choices at different times. For instance I'm working on one right now and I do not get the "anim (sequence)" choice (which works on the iPad). Other times I do have that choice. How do I control that?
by mediavets » Thu Oct 10, 2013 8:18 pm
CCBain wrote:Thanks! One thing I can't figure out concerning the Hotspot Properties is why the choices vary. When I highlight a link between two panos, in the Display area, under Object, I get different choices at different times. For instance I'm working on one right now and I do not get the "anim (sequence)" choice (which works on the iPad). Other times I do have that choice. How do I control that?
Are they the same type of hotspot?
