cant select the map option
boogoo
by boogoo » Sun Sep 29, 2013 6:45 am
i am unable to enable the map option kindly guide
by mediavets » Sun Sep 29, 2013 8:30 am
boogoo wrote:i am unable to enable the map option kindly guide
Do you mean the Map extra or the Panotour maps extra?
Which version of the software do you have, Panotour or Panotour Pro?
boogoo
by boogoo » Sun Sep 29, 2013 4:50 pm
i have pro 1.8
i mean when u go to extra and select map but the enable is not selectable
by mediavets » Sun Sep 29, 2013 6:42 pm
boogoo wrote:i have pro 1.8
There is no Enable check box on the Map extra - see screenshot 1.
You have to select the graphic file you wish to use as the Map before you can set the various options - screenshot 2.
boogoo
by boogoo » Sun Sep 29, 2013 6:44 pm
thanks
but can guide me where i get this file (i have a address and want to show that on the map for that pano
by mediavets » Sun Sep 29, 2013 7:03 pm
boogoo wrote:thanks
Then you need to use the Panotour maps extra not the Map extra.
The Google Maps layer is no longer supported ( Google withdrew support for their Flash API) so you will have to use the Bing or Open Streetmap map layer options .
To use the Bing option you need to get a Bing maps key.
The Panotour Maps extra in PTP 1.8 is Flash only so will not be displayed on iDevices.
Support for Google maps returns with PTP 2.x.
boogoo
by boogoo » Sun Sep 29, 2013 7:26 pm
thanks so much for taking the time
but i am a little confused for the following
what is difference between map extra and panatour extra?
and can I bother you to guide me a few steps that show the property in the map and then the pano starts showing the property
thanks a million
by mediavets » Sun Sep 29, 2013 7:30 pm
boogoo wrote:thanks so much for taking the time
The Map extra utilises your own map graphic - you create or acquire it.
The Panotour maps extra utilises online mapping services to provide/display the map.
