How to add labels
stillstonevisions
How to add labels
by stillstonevisions » Mon Sep 23, 2013 10:51 pm
My customer wants me to add a few text labels atop objects in the panoramas. I know I could go back and add them in Photoshop in the panorama image files, but it would be easier if there's a way to do it in PTP. These labels won't be hotspots. Can such a label be added?
Thanks,
Paul
stillstonevisions
by stillstonevisions » Mon Sep 23, 2013 11:52 pm
I think I figured this out. Add a hotspot without a link and keyed to an image file under "Display". Is that the best way?
by mediavets » Tue Sep 24, 2013 9:22 am
stillstonevisions wrote:I think I figured this out. Add a hotspot without a link and keyed to an image file under "Display". Is that the best way?
Yes, if you wish the label to be displayed all the time; Display/Object/Other.. then select your custom graphic text.
If you use a format which supports transparency - such as PNG - then PTP will honour that.
Many users have requested a Text type hotspot for PTP 2.x for exactly this labelling purpose, but there is as yet no committment from Kolor for this feature.
stillstonevisions
by stillstonevisions » Tue Sep 24, 2013 2:14 pm
Thank you.
Paul
stillstonevisions
Re: How to add labels
by stillstonevisions » Thu Mar 06, 2014 7:50 pm
Has this "text-type hotspot" yet been added to PTP2.0? If so, how do I find it. If not, what is the best way to place a non-rotating label near the top of a pano to indicate the name of the space being viewed?
Similarly, what is the best way to place a non-rotating logo image in a corner of the pano?
Are these documented in the current docs? If so, please feel free to refer me to the page number.
Thank you
Paul
by mediavets » Thu Mar 06, 2014 9:11 pm
stillstonevisions wrote:Has this "text-type hotspot" yet been added to PTP2.0?
No.
For PTP 2.x, use the Title plugin in the Text zone.
For PTP 2.x, u se the Logo plugin in the Image Zone.
Thank you
Paul
http://www.autopano.net/wiki-en/action/ ... ns_library
stillstonevisions
by stillstonevisions » Thu Mar 06, 2014 11:44 pm
I figured out how to change the name of the pano without changing its file name. I guess that would be the way to do this, correct? I find the documentation on these points all too brief and lacking in detail.
by mediavets » Thu Mar 06, 2014 11:49 pm
stillstonevisions wrote:I figured out how to change the name of the pano without changing its file name. I guess that would be the way to do this, correct?
Yes.
