Load a pano with the same angle of view as the previous pano?
goshiota
by goshiota » Wed Aug 21, 2013 10:30 pm
I'm pretty sure that it is not possible to set a pano to load with the same angle of view as the previous pano within PTP? I'm basically trying to have two different versions of the same vantage point, sort of like a day to night conversion, that will load at the same pitch and yaw as the previously viewed.
Thanks in advance for any suggestions.
-Jeremy
by mediavets » Wed Aug 21, 2013 10:55 pm
goshiota wrote:Hello,
-Jeremy
It would require additional hand coding.
goshiota
by goshiota » Thu Aug 22, 2013 5:43 am
-Jeremy
Thank you for the reply. I assumed as much. But I was hoping that someone that has done that sort of coding can share their knowledge.
I'll keep hoping someone can offer input on this.
Thanks,
Jeremy
