Custom map hotspots
medibot
Custom map hotspots
by medibot » Tue Aug 20, 2013 5:38 pm
Hello forum,
I’ve just got my panotour pro licence:D. So have a noobie question. Is it possible to have a hotspot as an image on the map feature. Rather than just a circle which is a bit boring.
Thanks for any help
by mediavets » Tue Aug 20, 2013 7:48 pm
medibot wrote:Hello forum,
Thanks for any help
Welcome to the forum...
Are you using Panotour Pro (PTP) 1.8 or 2.x?
In PTP 1.8 you can choose to use a custom graphic...select Other for the Display/Object and then the image you wish to use:
medibot
by medibot » Wed Aug 21, 2013 1:52 am
Perfect, thats just what I was looking for.
Thank you so much.
