Panotour Pro 2 - Beta Test
kitzhost
by kitzhost » Tue Aug 20, 2013 1:47 pm
i´ve buyed Panotour 1.8 and now i´ve buyed Panotour 2.0. How can i test a beta Version from Panotour 2?
My Account is: info@kitzhost.com
Regards
by mediavets » Tue Aug 20, 2013 2:15 pm
kitzhost wrote:Hello,
I've buyed Panotour 1.8 and now i´ve buyed Panotour 2.0. How can i test a beta Version from Panotour 2?
Regards
Contact Kolor using the contact form:
http://www.kolor.com/contact.html
Explain that you have licenses for PTP 1.8 and 2.x and ask them to register you on the Kolor VIProom forum set up to support pre-release testing and use of PTP 2.x.
There you will find download links for PTP 2.x and per support with input from the developers.
kitzhost
by kitzhost » Tue Aug 20, 2013 2:23 pm
done!
Thanks for help. I hope the Kolor´s Team answers fast :D
Regards
