animate GIF
Tonio
animate GIF
by Tonio » Mon Aug 19, 2013 1:48 pm
Hi everybody !
I really need to integrate an animate GIF in a virtual tour. But ... it don't work ( V1.8). Is it possible with Panotour V2 ?
Or should i convert my GIF into a video ?
Thanks a lot for your help !
Antoine
by mediavets » Mon Aug 19, 2013 2:11 pm
Tonio wrote:Hi everybody !
Antoine
How did you want to use the animated GIF?
Tonio
by Tonio » Mon Aug 19, 2013 3:17 pm
as a picture ... with a hot spot.
by mediavets » Mon Aug 19, 2013 3:29 pm
Tonio wrote:as a picture ... with a hot spot.
Then, yes, better to use a supported video format.
But I expect you know that video is not supported in mobile-compatible tours (for iDevices) created with PTP 1.8?
Tonio
by Tonio » Mon Aug 19, 2013 3:35 pm
ok ! thanks for you answer ... these virtual tours are provided for a fixed touch sreen. Not mobile device ...
And PTP 2 ? ... mayb i can wait couple of weeks to have a fixed one.
Wetsnapper
Re: animate GIF
by Wetsnapper » Tue Apr 01, 2014 10:49 am
Any joy with this one?
I'd like to include some animated gifs opened from a spot (reasons: smaller file size and higher res - better clarity - and adjustable frame rate to name but a few) I've tried converting to video, but from a 5mb gif file they go up to 20mb and loose image sharpness.
Any ideas?
Re: animate GIF
by mediavets » Tue Apr 01, 2014 2:25 pm
Wetsnapper wrote:Any joy with this one?
Any ideas?
Are you using PTP 1.8 or PTP 2.x?
Wetsnapper
Re: animate GIF
by Wetsnapper » Tue Apr 01, 2014 2:32 pm
2.0, but after a morning "playing" I've found a workaround, still not the quality (image sharpness) I was hoping for but I think I'm there...I'd prefer to add gifs though :0)
Re: animate GIF
by mediavets » Tue Apr 01, 2014 2:36 pm
Wetsnapper wrote:2.0, but after a morning "playing" I've found a workaround, still not the quality (image sharpness) I was hoping for but I think I'm there...I'd prefer to add gifs though :0)
OK - I asked because this topic relates to PTP 1.8.
Anyway - with PTP 2.x did you try displaying your animated GIF in a web site veiwer box?
Wetsnapper
Re: animate GIF
by Wetsnapper » Tue Apr 01, 2014 2:49 pm
This was the only topic I found using the search and thought it's as good a place as any to start/ask
Website viewer box? :?
Via (choose action...basic>open a website)?
How do you get it in a box? is it a nice neat pop out box, or a browser window?
Many thanx
Re: animate GIF
by mediavets » Tue Apr 01, 2014 4:55 pm
Wetsnapper wrote:This was the only topic I found using the search and thought it's as good a place as any to start/ask
Many thanx
Wetsnapper
Re: animate GIF
by Wetsnapper » Tue Apr 01, 2014 5:11 pm
Gah! Something else to remember :0)
Worked a treat, thank you
