Panotour Pro - 2.0 License
teddy
by teddy » Fri Aug 16, 2013 1:10 pm
Panotour 2.0 will have a portable license, or not?
by mediavets » Fri Aug 16, 2013 1:37 pm
teddy wrote:Panotour 2.0 will have a portable license, or not?
What do you mean/understand by a portable license?
teddy
by teddy » Fri Aug 16, 2013 1:44 pm
When you buy a software you will receive a key code (license). This key code allow to use the software only at 1 computer in a moment. But, you you have a friend, you pass him the license- and in this case only him can work with the software-and then finish the work and pass you back the license.
Many company - that made software for virtual tours made this kind of license
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Fri Aug 16, 2013 7:07 pm
Hum not sure you can do that. Most software editors allow you to use licence on multiple computers so long you are the only user of the licence (for example your laptop and your desktop) but I don't think they allow you to pass the licence to someone else temporary ! perhaps you should ask Kolor directly or check in details their licence to be sure you are allowed to do that.
Blog: http://www.skivr.com
teddy
by teddy » Sat Aug 17, 2013 5:49 am
Tks Vincen
by AlexandreJ » Mon Aug 19, 2013 8:34 am
Our license policy is user based, that means, it is an user that buys the software, not a computer. You can then install it on a laptop and desktop if you are the user of these both computer.
teddy
by teddy » Mon Aug 19, 2013 2:25 pm
@AlexandreJ
Tkk for your details in reply
