Infopoint switch on and off
markusViVi
by markusViVi » Fri Aug 09, 2013 11:10 pm
Hi, I'm new user from Panotour Pro, and I saw a Panorama where you can switch on and off the infopoints by bottoms, is this also possible in Panatour pro?
http://www.gpix.at/Gpix.at-Gigapixel_gpath,horn360,pid,9112,type,gpix.html
Would be great if somebody can help me, because I need this feature for a project.
Many thanks
Markus
by mediavets » Fri Aug 09, 2013 11:29 pm
markusViVi wrote:Hi, I'm new user from Panotour Pro, and I saw a Panorama where you can switch on and off the infopoints by bottoms, is this also possible in Panatour pro?
Many thanks
Markus
Welcome to the forum...
Panotour Pro 2.x has the option to place a button on the control/navigation bar to turn hotspots on and off - see screenshot below.
How recently did you purchase your PTP 1.8 license?
If very recently you may also have received a license key for PTP 2.x.
In which case use the contact form to ask Kolor to register you on the Kolor VIP forum set up to support the testing and use of PTP 2.x before it is released. There you will find download links and peer support.
http://www.kolor.com/contact.html
Currently PTP 2.x is in alpha state - incomplete with some bugs - but it is uable for production work if you so chose.
markusViVi
by markusViVi » Sat Aug 10, 2013 8:41 pm
Thank's for the information. When do you think that 2.0 will start in the final release?
MArkus
by mediavets » Sat Aug 10, 2013 8:52 pm
markusViVi wrote:Thank's for the information. When do you think that 2.0 will start in the final release?
MArkus
Not a clue... I don't work for Kolor and they haven't hinted at a date for Final Release as far as I know.
But if you have a license you can use it in Alpha state today for production work.
markusViVi
Re: Infopoint switch on and off
by markusViVi » Sat Mar 15, 2014 6:23 pm
After a view month working with 2.0 I like to reactivate this forum.
Yes I have now a button in the Control-bar where I can turn hotspots on and off.
But only all of them. In the example
you can choose different groups of spots to turn on and off by an toggle button
see in the right up angle in the Panorama the small Icons.
Has someone an idea how to realise this in PTP?
Thanks a lot
Markus
