i need help with android
panostudio54
by panostudio54 » Wed Aug 07, 2013 2:31 am
good morning to all: I just bought ptp 1.8 and I can not see the files on android devices, someone could help me, thank tou very much
by Destiny » Wed Aug 07, 2013 8:09 am
Hi.. You can only view a tour on an Android up to build 4, if you have Android 4+, you will not be able to view it since Flash is not supported.. The iDevice is only for Apple iPads... However.. PTP V2 is heaps better.. Its an awesome software app but its still under development. You can buy it but you will need to understand there are still bugs and some features are missing.. PTP V2 is getting better and better with every Alpha build. My advise would be to buy it, with the above understanding.. Then apply to join the VIP Room where you will have access to download all current versions.. Its all done on a personal level to maintain records on it...
Buy it via the online shop and then apply to join the VIP Room at the Kolor Blog...
by mediavets » Wed Aug 07, 2013 8:56 am
panostudio54 wrote:good morning to all: I just bought ptp 1.8 and I can not see the files on android devices, someone could help me, thank tou very much
Welcome to the forum...
If you have 'just' bought PTP 1.8 the you should also have received a license key for PTP 2.x.
The HTML5/mobile compatiblity offered by PTP 1.8 is exclusively for Apple iDevices.
As Destiny says, PTP 2.x has much wider support for mobile devices, including many Android devices.
Use the contact form to ask Kolor to register you on the Kolor VIPforum set up to support pre-release tesing/use of PTP 2.x where you will find download links and peer support.
http://www.kolor.com/contact.html
PTP 2.x is currently in alpha state - incomplete and with some bugs - but you may use it for production work if you have a license key should you wish to.
tamiro
Likes: 12 posts
by tamiro » Wed Aug 07, 2013 6:36 pm
i have Galaxy Note2 with the Android 4.2
and it display flash and HTML5
if you can translate this page you will be able to use flash as well
http://www.tgspot.co.il/how-to-get-flash-back-on-your-android-device/
digipano
by digipano » Tue Aug 13, 2013 1:07 pm
Destiny wrote:Hi.. You can only view a tour on an Android up to build 4, if you have Android 4+, you will not be able to view it since Flash is not supported..
Just wondering why did Adobe dropped the flash support from android 4.xx ?
Although users can still install flash apk to get the flash support, most peoplewont do it unless absolutely required.
http://www.addictivetips.com/android/how-to-install-adobe-flash-player-on-any-android-4-1-4-2-jelly-bean-device/
by mediavets » Tue Aug 13, 2013 1:49 pm
Well they - Adobe - are not going to change their 'mind' so just get PTP 2.x and forget about it? ;)
