Tour online
Delaetphotography
Tour online
by Delaetphotography » Thu Jul 25, 2013 3:34 pm
Hey Guys
Another question, i saved my tour with all the html,.. now what do i need to do to put my tour on line, so i can send a link to my clients or i can put a link on my blog.
I took a print screen from the map i've got with all the files,...
Steven
by mediavets » Thu Jul 25, 2013 3:40 pm
Either :
1. Get yourself some web space and upload the whole lot using an FTP program, then you can link to the HTML file.
Or:
2. If you have WordPress blog then check out PanoPress:
http://www.panopress.org/
by klausesser » Thu Jul 25, 2013 4:40 pm
Delaetphotography wrote:Hey Guys
Steven
Hey Steven - again: NO SPACES in filenames! It wouldn´t work on servers.
I wrote that already in my email.
In your screenshot there ARE spaces in the filenams.
;):cool:
best Klaus
PS: Andrew´s right of course.
Delaetphotography
by Delaetphotography » Mon Jul 29, 2013 4:27 pm
Thanks for the reply's.
So i created a wordpress with localhost and i use the plugin to put my tours on the blog, but it's only local so i am the only one who can see it and i can't show it to someone else or send it to someone else.
How can i go online?
Best
Steven
by klausesser » Mon Jul 29, 2013 7:09 pm
Delaetphotography wrote:Thanks for the reply's.
Best
Steven
Sorry - no idea with wordpress.
best Klaus
by mediavets » Mon Jul 29, 2013 8:03 pm
Best
Steven
Find a web hosting service which offers Wordpress - many do.
Then do the same thing online as you've fone offline.
Delaetphotography
by Delaetphotography » Mon Aug 05, 2013 8:12 pm
Hey guys
When i want to put the swf file on my wordpress page, i always get this screen (check picture).
I've don't understand how i can get my tours with panopress on my wordpress.
The explination on the panopress website i don't understand.
Best
Steven
by mediavets » Mon Aug 05, 2013 8:22 pm
Is the file there?
When I try to access it it appears not to be there:
http://www.delaetphotography.be/wp-content/uploads/2013/08/Test11.xml
Sam Rohn
by Sam Rohn » Tue Aug 06, 2013 3:13 am
1st, make sure you upload all files and folders required for your tour into the same directory on your site, if you do not upload all required files into the same directory things will probably not work right
using panotour pro 1.8 i get something like the attached screenshot for a 3 pano tour, and i would upload the contents of the "build" folder into a folder called "my-pano-name" (example name) inside of wp-content/uploads
so my files would then have a path like
wp-content/uploads/my-pano-name/virtualtour.html etc
and you would embed in your wordpress site using the panopress shortcode like this
[pano file="my-pano-name/virtualtour.html"]
best to use panopress html embed for panotour pro rather than xml or swf, using xml embed MAY require some adjustments to your xml
you can change the name of the html files and the containing folder, but do not change the name of the xml or swf unless you know what you are doing
also a good idea to avoid spaces in file names, use dashes "-" instead, "my-pano" not "my pano"
sam
Sam Rohn :: 360° Panoramic Photography :: www.samrohn.com :: Location Scout :: www.nylocations.com :: New York City
PanoPress :: WordPress Plugin for 360° Panoramas in Flash & HTML5 :: www.panopress.org
