html 5 only
as@aeo
html 5 only
by as@aeo » Thu Jul 25, 2013 1:14 pm
can somebody tell me if it will be possible to only use html 5 instead of flash and html 5 (depending on device) for the virtual tours created with the new panotour pro 2.0?
thx
Adrian
Didi
by Didi » Mon Jul 29, 2013 12:46 pm
i have also the problem i work for l'assemblée nationale du Québec and they don't want the FLASH (i don't know why)
by Destiny » Mon Jul 29, 2013 1:12 pm
Hi.. you can add the suffix ?html5=always or ?html5=prefer to the end of your url....
Creating a Tour using PTP V2, it should just default to html5 when viewing it on an Android 4+ as long as you have ticked to build it as html5.. You can just build the Tour using html5 and ignore Flash if you wanted to....
