APG 3+ back to basics.... HOW TO USE IT? 2
by klausesser » Wed Aug 07, 2013 11:01 pm
mediavets wrote:APG recognises the lens as a fisheye with a 35mm equiv. focal length of 15mm on D800 in DX mode which shoulkd be good enough.
No. Not at all.
It´s still 10,5mm on a D800. No matter the used sensor size: a 10,5mm stays a 10,5mm - on which camera ever.
Maybe here´s a problem: it IS a 10,5mm on a FX simulating to be a DX. A problem can occur when there are confusing data in the EXIF:
IF the D800 tells an application to be a DX because it´s in DX-mode - the application MIGHT BE thinking it must change the focal-values . .
but the question is: what are the EXIFs telling the app??
Do the EXIF´s KNOW AT ALL it´s a FX simulating a DX? Do the EXIFs tell the app it´s a FX simulating a DX?
Does the app UNDERSTAND this informations? HOW do the apps interprete a FX simulating a DX?
In my experiences there are two kind of EXIFs: 1) from the camera-body, 2) from the lens.
Now the camerabody is a FX by the EXIFs, the lens is a DX by the EXIFs.
I don´t know how Nikon "translate" the FX to DX via the EXIFs to an application.
by klausesser » Wed Aug 07, 2013 11:06 pm
mediavets wrote:
klausesser wrote:
Destiny wrote:Even though, I had a RMS of 3.86 with Quick Optimise and a 3.66 with Full Optimise stating its was Very Good, however the final stitch was NOT Very Good...
No surprise: 3.66 is far from being "very good". "Very good" is around RMS 1 or 1.5 - at least with higher resolution than an average fisheye pano.
Irrelevant I think -
Not in my experience.
by klausesser » Wed Aug 07, 2013 11:33 pm
Destiny wrote:So, a question for you Klaus.. Do you achieve an equally good results using a Fisheye as with a normal prime lens...??.
see it here: Canon 5D2, 2,8/15mm Canon fisheye, 3 steps @2EV, processed in Photomatix, stitched in APG 3.0.7
http://360impressions.de/Mies/
by mediavets » Wed Aug 07, 2013 11:33 pm
No. Not at all.
Of course. I said "35mm equiv. focal length of 15mm on D800 in DX mode".
klausesser wrote:Maybe here´s a problem: it IS a 10,5mm on a FX simulating to be a DX. A problem can occur when there are confusing data in the EXIF:
Here's an EXIF from one of the images form the sameple image set. Do you see any problems here?
by klausesser » Wed Aug 07, 2013 11:45 pm
mediavets wrote:Do you see any problems here?
No - but maybe Photomatix or APG do. I´m not a specialist regarding EXIFs and how they´re interpreted in different applications. Are you?
I for example know applications which don´t even read particular values in XMLs . . :cool:
The point is: there definitely IS a reason for the issue. And: me, myselfs and i suspect the issue is in some setting.
by Destiny » Thu Aug 08, 2013 6:45 am
SUCCESS AT LAST...!!!! and I know exactly what was wrong..
The rusty old tin can is shining bright..!!
Destiny....
by Destiny » Thu Aug 08, 2013 8:21 am
My new images are available in my DropBox.. All I did was load them into APG, detect and render... Thats it.. ;).. In Photoshop, I used Sharpen once.. NOT sharpen edges.. You might find the image a little too vivid but I like it.. Feel free to edit it as you want.. but. most important this is an opportunity to test the stitching quality using APG 3 and 2.6 on YOUR computer...
Thank you..
Previous
