Destiny wrote:Thats just a text file...
Destiny wrote:It doesn't open a pano.. Its just a 1meg text file and auto opens it. Nothing I can change..
marzipano wrote:Destiny wrote:It doesn't open a pano.. Its just a 1meg text file and auto opens it. Nothing I can change..
I think you have to move it to the directory containing the Nikon Raw (nef) images and then double click it (or open with apg) to open the pano for edit/render
Martin
Destiny wrote:Ok.. I worked it out.. I removed the .txt at the end file name and it was fine. It opened.
Not sure what you have done or think you have done but its horrible.. Sorry.. Not even close to a fused pano.. and it will not render; and with this warning you haven't set it to fusion but rather anti ghost, which is the wrong settings for fusion..
Nothing opened in the left main panel so I do not know what setting you set..
HansKeesom wrote:Destiny wrote:Ok.. I worked it out.. I removed the .txt at the end file name and it was fine. It opened.
You asked for the .PANO so that what you received. The photoshop-file is looking much better then what is on your screen.
No surpise it will not render, did you see my screenshot showing 61 GB of RAM was being used rendering your file?
I advise you to render it without antighost etc and check that the stitching itselve is perfect (no broken line)
Dropbox upload went wrong somehow, hope to send you link to you in about an hour
file is huge and a bit orange but you should be able to correct that.
Destiny wrote:I did try to render without antighost.. This is what happened...
Destiny..HansKeesom wrote:Destiny wrote:Ok.. I worked it out.. I removed the .txt at the end file name and it was fine. It opened.
Destiny wrote:Hans.. I really appreciated your efforts but its not what I was really hoping for.. I cannot see any stitching and there is no fusion at all in this.. The psd file took quite a while to download..
Destiny wrote:I am not using antighost. That is the issue APG will not change your file to Fusion even after I set it to Fusing as you can see... I set it to Fusion but it errors suggesting its set to antighost.. Your attitude is confusing.. You wanted me to send you the pano.. I did not ask you to do it.. All I have done is post up the results that you sent me without any changes.. None of which are fusion. Not even close. I cannot even see the stitchings they are so dark.... One has pink lights and other is so dark with blowout on the lights..
Not to worry.. I will work it out.... It was supposed to look like this.. http://www.kolor.com/forum/p119260-2013-07-23-20-46-42#p119260
I sent you the same RAW images as I used in this pano.. APG cannot do this which is the point I am making.. Not even close but you suggested that you could..
Destiny wrote:No it doesn't.. As I have already posted up, it looks like this in Photoshop CS6
http://www.kolor.com/forum/p119364-today-20-06-21#p119364
But even it it did look like your orange pano. In all honestly, are you happy with that.. With all your RAM and CPU power, this is your best effort.. I think you ned to agree that even with all your PC resources, there is something fundamentally wrong with APG fusion process..
I personally am going to move on from it.. I have tried very hard to make it work but even if I spent hours and had the hardware to achieve the results I was looking for, as in the pano results using Photomatix and PTGui, I still would not use it since I could never repeat the results without putting in a lot of time and effort even if had the computer hardware like yours to deal with processing my images..
I will work on getting my stitching right over the weekend.. I will continue to use Photomatix and try to get ABG to stitch it as best I can.. I can only assume, after Martin suggested, I should be able to active a low RMS with my gear, so I can only assume my NP is still not right... This is not the first time I have spend hours trying to work out the fusion/hdr process with APG..
Like I said; Thank you for your efforts but it was not the results I was looking for..
Destiny wrote:there is something fundamentally wrong with APG fusion process..
Destiny wrote:What on earth are you talking about.. I have stated that I cannot get APG to change your file from Antighost to Fusion . IT WILL NOT CHANGE.. Therefore it will not let me render it..
What do you mean. "I don't to see it.." See what..?? I have only posted up what you sent me.. What don't I want to see...??
"I did do it, you just don't want to see it. That is a problem I can not solve for you."
The reason why you cannot solve this issue is due to the APG fusion process. You suggested with all your PC power that you could solve the issue but you became over confident..
I have just loaded the same RAW files into APG.. As stacks.. I set it to index the 3rd images.. Now I have PINK lights.. I tell you now.. there is a lot more to all this than I can explain.. If I export as TIFs I do not get this..
The only real difference between what you achieved and I achieved, YOU achieved it a lot quicker due to your hardware. But the results are the same. TERRIBLE.. HORRIBLE.. And even loading RAW as you did, I am testing it now, I still cannot get the sliders to work.. Nothing happens.. But with all your hardware resources you should have been able to.. If not, then its a big bug in APG.. and I really do think this is the case.. I have just tried to render my file, same as your file, I get the same error.. It cannot render antighost yet I have not set it to anitghost, its set to fusion.. It a bug..
klausesser wrote:Destiny - let´s talk straight:
"Virtual Tours and 3D/360 Object/Product Photographer"
That´s what you claim to be.
But you´re not even able to recognize and accept very simple facts - instead you´re making funny statements and complain about "bugs" over and over again.
Everything that doesn´t work for you MUST be a "bug" and definitely an error is not on your side.
I tried again and again to help you, telling tips and tricks, give advises and so on. Your reaction then was rather self-opinionated.
What´s going on with Hans starts to go the same way. It´s a pain in the *** to read this to be honest.
I wish you luck for whatever you´re gonna do.
mediavets wrote:May I remind contributors to this thread of one of the forum rules:
4. No post that attack, insult, flame, defame or abuse other members is allowed.
Thank you...
Destiny wrote:This a long video live as it happens for me.. if you do not want to watch paint dry, skip to the last two minutes..
http://www.destinyvirtualtours.com/APGexposureweights/raw.html
You will see my issue.. I am sure I am doiang all processes correctly..
