Panotour embeded and uploaded - shows error message
Baldev
by Baldev » Thu Jul 04, 2013 10:52 pm
panotour show is uploaded, pics as well, all on server. link to swf-file in subfolder is also correct.
but still pics can't be found.
To embed the tour, i used the code which is suggested here:
http://www.autopano.net/wiki-en/action/view/Panotour_-_Web_publishing#STANDARD_CODE_FOR_WEB_PUBLISHING
i get an error message, that all images can't be found.
Thank you for help.
by gkaefer » Fri Jul 05, 2013 8:58 pm
Baldev wrote:Hello,
Thank you for help.
can you post the link to your Problem pano?
check that all files got uploaded including all subdirs and files in subdirs...
check that all files and files in subdirs are world readable and all dirs and subdirs world executable...
if you mean the "Embed XML files" and the "Embed all data" Option inside ptp 1.8 Project properties than why at all do you wanna use it? it only slows down Performance for end user because they first have to download all data first before the pano starts on Screen to be visible.
ptp2.0 does no longer has this "embed" Option, here you will have an Option to "encrypt your XML file" (under build->Protection->Build configuration files). this encryption is identical to krpanos equivalent Tools...
edgar_ali
Liked in: 3 posts
Re: Panotour embeded and uploaded - shows error message
by edgar_ali » Wed Jan 22, 2014 12:05 am
I have created a simple tour using Panatour 1.8.
I opened the tour using my safari browser and I was able to see it.
I uploaded my tour to the following address and there is nothing:
http://www.screencast.com/t/rch1xOZkjvz
When uploading in a different host, I get the following message:
http://www.screencast.com/t/wnx139q1fXM
It says something about error: download of untitleddata... (check the screenshot attached above)
How Can I fix this problen so I can see my tour
by mediavets » Wed Jan 22, 2014 12:11 am
edgar_ali wrote:I have created a simple tour using Panatour 1.8.
Please don't duplicate post.
See: viewtopic.php?f=33&t=18371&p=135611#p135611
