tablet/smartphones with new android versions
as@aeo
by as@aeo » Wed Jul 03, 2013 1:55 pm
can somebody tell me, how I can fix the "android-problem"? I used to play my virtual tours (created with panotour pro) on PC, Ipad, Iphone or my smartphone (with an older android-version). Everything worked fine on each device. Now I have a new smartphone with a new android-version and a tablet with a new android-version too. both do not play my tours, the failure-notice is "this android version does not support flash". But it neither opens the flash version nor switches to the html5-version. This is a big problem for us!! Can somebody help with this? Can't be, that it is impossible to watch virtual tours on android devices..
thx
Adrian
by mediavets » Wed Jul 03, 2013 6:35 pm
PTP 2.x will solve your problem.
by Destiny » Thu Jul 04, 2013 12:38 am
Hi Adrian...
Yes, Andrew is sooo right... You can test it here.. http://www.kolor.com/ptp2
PTP V2 panos work really well on my Samsung Note with Android 4+
