KRPano Demo Message on Android
wshackne
by wshackne » Thu Jun 13, 2013 10:43 pm
I've been trying to get my tours to work on Android. Did some digging and found that the current version of PanoTourPro (1.8) only supports iPhone because it uses an older version of krpano. I did some testing and found that the issue was simply with the device detection. The actual tour that PTP 1.8 produces works fine on an Android device without flash. I looked through the KRPano documentation and the swfkrpano.js file that detects the device and either delivers the Flash or mobile tours. I was able to simply download the viewer from http://www.krpano.com/download/ and swap out the swfkrpano.js. This seemed to work well in all of the Android and iOS devices I have tested. Tour is up at http://www.southportway.com/portals/12/tour/mobile/virtualtour.html.
The problem I have is that the the virtual tour demo watermark is showing on iPhone only! It looks fine on all other devices. Any ideas about this?
Spence
Likes: 3 posts
Liked in: 225 posts
by Destiny » Thu Jun 13, 2013 10:50 pm
Hi Spence..
PTP V2 will work on Android 4.+ You just need to wait a little while longer.. ;) V1.8 will not!, accept with up to Android -4.0 Flash will work as I understand..
wshackne
by wshackne » Fri Jun 14, 2013 2:51 am
Actually, I don't! As I mentioned I just copied swfkrpano.js from the krpano-1.16.4 package to my tour and it now works fine on both Android and iOS. I can't for the life of my figure out why the good folks at Kolor don't just do this in a maintenance release.
Also, I fixed the license issue by copying my krpano license files into the swfobject directory.
Hope this helps some one!
Spence
zimmerman
by zimmerman » Sat Jul 27, 2013 5:39 pm
Hi, I copied swfkrpano.js from the krpano-1.16.4 and the krpanoiphone.license.js and put that into to the swfobject directory (folder) it works fine on my Android but the krpano logo appeares on my iPad, how do I get rid of that or am I missing something? (I have the Panotour Por license)
/Stefan
by klausesser » Sat Jul 27, 2013 6:17 pm
wshackne wrote:Actually, I don't! As I mentioned I just copied swfkrpano.js from the krpano-1.16.4 package to my tour and it now works fine on both Android and iOS. I can't for the life of my figure out why the good folks at Kolor don't just do this in a maintenance release.
Spence
Thank you, Spence! Well done, good idea!
wshackne
by wshackne » Sun Jul 28, 2013 12:48 am
zimmerman....I was able to fix the watermark issue by making sure the license was present in the directory with the kpano js files. Good luck!
zimmerman
by zimmerman » Wed Jul 31, 2013 4:07 pm
Thankyou, its working now.
http://www.360mediaproduction.com/
If you want to have a look.
/Stefan Zimmerman
