Modify the behaving of the floorplan map ?
Alain
by Alain » Sun May 19, 2013 6:40 am
Hi
I'm just testing Panotour Pro.
I wanna do an indoor tour with a floorplan for orientation. I use the "Map-Plugin" for that.
But I don't like the behaving of the floorplan: It just scales up and down by clicking on it and that looks kind of "cheap" from my graphical point of view.
Is there a way to modify the behaving of the floorplan like smootly sliding in from a sidebar instead of scaling up and down ?
Kind regards
Alain
by mediavets » Sun May 19, 2013 12:00 pm
Alain wrote:Hi
Kind regards
Alain
Only by hand coding the XML.
