Pano Blur Effect
goshiota
Pano Blur Effect
by goshiota » Fri May 03, 2013 10:18 pm
Hi Forum,
Does anyone happen to know how to make a panorama "blur" once a hotspot image is opened, and then un-blur once the image is closed? I'm guessing it is code that is inserted into the XML?
Thanks,
Jeremy
goshiota
by goshiota » Thu May 16, 2013 6:55 am
I'm bummed I haven't been able to recieve a solution for this. Perhaps I can ask in a different way.
I have found the "imageadjust" plugin from the KRPano site. That plugin will "blur" a tour, among other things if desired. I am trying now to figure out how to control when the plugin is enabled or disabled. If I enter the following code...
<plugin name="imageadjust" url="plugins/imageadjust.swf" enabled="true" saturation="0" hue="0" />
into the main XML or the pano XML, the tour does blur when it loads. However, I wish for the plugin to be "disabled" when the tour load but "enable" when a particular hotspot is clicked. In my case, I want the plugin to enable when a hotspot is clicked, which opens a photo, and in turn blurs the background pano. Of course I want it to disable again once the photo is clicked to close it.
I guess I'll go ahead and include the code for the hotspot of interest:
<hotspot name="spot0" onclick="closeallobjects();set(plugin[spot0object].visible,true);tween(plugin[spot0object].alpha, 1);switch(autorotate.enabled);set(plugin[autorotationOFF];" url="indexdata/graphics/spots/spot0.png" ath="1.29125" atv="22.2414" width="36" height="36"/>
<plugin name="spot0object" visible="false" url="indexdata/graphics/spots/object0.png" align="center" alpha="0" onclick="closespot0object();switch(autorotate.enabled);set(plugin[autorotationON];" width="prop" height="50%"/>
<action name="closespot0object">
if(plugin[spot0object].visible,
tween(plugin[spot0object].alpha, 0);
delayedcall(0.5,set(plugin[spot0object].visible,false));
</action>
I will be eternally grateful to whoever can solve this for me.
Thanks,
Jeremy
msmazza
Re: Pano Blur Effect
by msmazza » Tue Feb 04, 2014 4:51 am
Hi Jeremy,
I'm looking for the same effect. Did you every figure this out?
Mike
by mediavets » Tue Feb 04, 2014 9:54 am
msmazza wrote:Hi Jeremy,
Mike
With PTP 2.x - not PTP 1.8 - the Gallery plugin offers the option of an overlay ('blur') over the pano when loaded:
