limiting the FOV
burake
limiting the FOV
by burake » Sun Apr 21, 2013 9:32 am
Dear forum members,
We made a virtual tour where the customer doesn't wish to show all the 360 degree at the starting panorama...The vertical FOV should stay by 180 degree but the horizontal must be limited...We couldn't change this while creating the tour; but we have made a change to the XML file of the concerning panorama:
hlookatmax="45" instead of "180" (hlookatmin unchanged "180")
and have achieved this satisfying result:
http://www.bilisimfotograf.com/images/sanal-tur/kanlaboratuvari/kanlaboratuvari.html
But iOS doesn't seem to recognize this change and on my iPad 4 I can see the whole 360 degree...Any idea how to solve this problem?
Any answer will be highly appreciated...
Best regards
Burak
by mediavets » Sun Apr 21, 2013 11:40 am
burake wrote:Dear forum members,
You can do it in fact even if the HFOV is 360.
What you do is manually change the HFOV setting (in PTP) to 359 then you'll see the crop handles on the H axis, do the crop then change the HFOV back to 360.
Best regards
Burak
Yes, iDevices don't 'honour' the crop on the H axis, only on the V axis.
A bug/limitation/feature of the krpano 1.0.8.15 HTML5 Panoarama Viewer I think.
I do not know of anyway to fix this.
burake
by burake » Sun Apr 21, 2013 12:47 pm
Thank you very much for your reply Andrew...You are alwasy very helpful; I appreciate it highly...
Best regards
Burak
by mediavets » Sun Apr 21, 2013 1:47 pm
burake wrote:Thank you very much for your reply Andrew...You are alwasy very helpful; I appreciate it highly...
Best regards
Burak
Update - it appears that the new krpano 1.16 HTML5 Panorama Viewer will 'honour' the crop on the H axis as well as the V axis.
burake
by burake » Sun Apr 21, 2013 7:10 pm
That's good news:)
