KRpano 1.16
Ian McCarney
KRpano 1.16
by Ian McCarney » Thu Mar 28, 2013 6:43 pm
Hi all
How do I upgrade Panotour pro from KRPano 1.0.8.14 to KRpano 1.16.? any help would be gratefully received.
Cheers!
Ian
by klausesser » Thu Mar 28, 2013 7:08 pm
Ian McCarney wrote:Hi all
Cheers!
Ian
AFAIK there is no such version. The actual version is 1.0.8. 15 and the upgrade from . . . 14 to 15 is free. Download it from the KRPano site.
But it´s not part of PanoTour Pro.
by mediavets » Thu Mar 28, 2013 7:28 pm
Cheers!
Ian
Ah but there is a krpano 1.16:
http://krpano.com/download/
They've changed the numbering system, so it's gone from 1.0.8.15 to 1.16.
Ian McCarney
by Ian McCarney » Thu Mar 28, 2013 8:18 pm
Thank you Mediavets for your reply. My question is more how do I point Panotour pro to look for the KRpano file as I have forgot how I did it when I installed. My only excuse is Im more of a press photographer than computer expert.
Kind regards
Ian
by gkaefer » Thu Mar 28, 2013 8:45 pm
Cheers!
Ian
swot... :lol:
by klausesser » Thu Mar 28, 2013 10:36 pm
Cheers!
Ian
oops! :D:cool:
rawtoast
by rawtoast » Fri Mar 29, 2013 11:34 pm
Greetings Everyone!
So can I download the new 1.16 from krpano.com and then have panotour pro 1.8 use the new files? Is there documentation of what to do procedure wise? I want to make sure I do it "the right way" the first time if it is indeed possible.
Thanks for your help!
The Newbie!
RawToast
by gkaefer » Fri Mar 29, 2013 11:52 pm
rawtoast wrote:Greetings Everyone!
The Newbie!
RawToast
for previous Version it was reported on Forum that you can create with ptp 1.8 your tour and than you do Exchange the relevant .js and .SWF files for plugins etc. but it was also reported that this may work but may also fail depending on plugin etc. So no guarantee.
aaronpriest
Likes: 4 posts
by aaronpriest » Tue Apr 09, 2013 9:20 pm
I swapped out the krpanoiphone.js, swfkrpano.js, gyro.js, and radar.js files. I got better Android support afterward, but didn't notice much of anything else on iPhones or iPads. I left the .swf files alone so far.
Where does PTP get the files from when you build a tour? I couldn't find them on my computer to swap them out there before building a tour. So I have to swap them out again every time I build a new tour.
Can't wait for PTP 2 if it is going to be the "official" GUI for KRpano as I've heard rumors of. Lots of things I'd love to do that I just don't know how. :-)
ATXcloud
by ATXcloud » Sun Apr 14, 2013 4:38 am
I've swapped out krpanoiphone.js, swfkrpano.js, gyro.js had success in viewing on an android with v4.0.1 o/s, but when viewed on my iPad, after a few minutes, i got a message, "KRpano demo version" (photo of message included below).
I tried including 1.0.8.14 krpanoiphone.licsense.js and still got the message.
Removed the 1.16's swfkrpano.js and I did not get the message, but no longer working with androids well.
Anybody experiencing this as well? Any ideas?
Here is a link that demonstates... http://www.atxcloud.com/island/2013/04/14/7/
Howdy from Deep in the Heart of Texas!
by gkaefer » Sun Apr 14, 2013 10:48 am
ATXcloud wrote:I've swapped out krpanoiphone.js, swfkrpano.js, gyro.js had success in viewing on an android with v4.0.1 o/s, but when viewed on my iPad, after a few minutes, i got a message, "KRpano demo version" (photo of message included below).
hmm. ptp 2.0 will be the official GUI for krpano 1.16...
ptp 2.0 upgrade will not be a free upgrade
so maybe using krpano 1.16 on ptp 1.18 created tours will also not be included...
would make sense, but no idea...
you could make a test: Export your krpano 1.0.8.14 license from ptp 1.8 and than try to use the licenses with the krpano 1.16 package. if you get the same demo issue it is like I assumed, if it works proper than it maybe a bug case...
aaronpriest
Likes: 4 posts
by aaronpriest » Sun Apr 14, 2013 1:47 pm
I too have experienced this a couple times on my iPad. Refreshing the page removed the demo notification. I suggest it is a bug.
