Can Panotour pro be used in desktop and laptop with same license?
alexojeda
Likes: 11 posts
by alexojeda » Thu Mar 28, 2013 7:59 am
I bought Panotour Pro and would like to know if I can install it and my desktop and laptop with the same license?
Many thanks
Alex Ojeda www.alexojeda.com
Novoflex Panorama VE-System 6/8
Canon Fisheye EF 8-15mm F/4L USM
Manfrotto Tripod
a a gruntpuddock
by a a gruntpuddock » Thu Mar 28, 2013 8:08 am
From the FAQ
"The license of Autopano Pro is a single-station license, i.e. you can only install the application on one computer. However, Kolor tolerates the installation of the application on several computers for individuals and self-employed persons insofar as you are the only user of the application on these computers."
alexojeda
Likes: 11 posts
by alexojeda » Thu Mar 28, 2013 8:16 am
Hi, many thanks! Yes, im the only user, I was using my laptop but it kept crashing I guess because of the filesize of the images, so I bought a desktop, which I will use from now on most of the time. I was wondering If I needed to unistall and deregister from my laptop, but its great that I can have it in both just in case.
Many thanks, again,
Alex
Manfrotto Tripod
