Installing Panotour Pro Branding Free License
goshiota
by goshiota » Wed Mar 20, 2013 12:58 am
I just upgraded my Panotour Pro License to the Branding Free License. I can't figure out how to update my license within the software. Can anyone help?
Thanks,
Jeremy
Likes: 14 posts
by bdd » Wed Mar 20, 2013 6:30 am
As the Branding Free License is used to remove some entries in the context menu, it is in the context menu parameters that you will register it.
Check the "Projet Properties/Extra/Context menu" tab.
This place to set the license is not really accurate and/or obvious, we will add it in the License menu in a future version.
by mediavets » Wed Mar 20, 2013 9:48 am
Here:
goshiota
by goshiota » Thu Mar 21, 2013 6:47 am
Thank you!!! That does indeed work.
I acutally did try that once, but it did not seem to save my new license info. Maybe it's because I did not generate a project after loading it? Anyway, it is installed when I launch the program now.
Thanks again!
--Jeremy
