GOOGLE MAPS APIs AND VIDEO.MP4
eacapture
by eacapture » Wed Mar 13, 2013 6:47 pm
Hello, I'm from Brazil, sorry my English.
I need your help: I can not put the google map, I've done the API key. The map where it should be, is black. In Opensrteet BingMaps also failed. The project is still offline.
And my other problem is when I attach a video.mp4, he is lying down and inverted.
Please help me out!
Thank you
by gkaefer » Wed Mar 13, 2013 6:56 pm
eacapture wrote:Hello, I'm from Brazil, sorry my English.
Please help me out!
Thank you
for which API Version do you have a key:
APIv2 (Flash) (supported by panotour pro 1.8 - but no new keys are releaed by google)
or APIv3 (JavaScript) (currently only with krpano, and witch next 2.0 panotour pro)
akphoto
by akphoto » Wed Mar 13, 2013 7:18 pm
eacapture wrote:... The project is still offline.
In offline mode, Google maps will not be displayed. If I understand your problem.
by mediavets » Wed Mar 13, 2013 7:25 pm
The Google maps option is no longer supported by the Panotour maps feature, unless you obtained an appropriate Flash API key before these were deprecated.
You should select the Bing maps option instead.
Check you have the Flash local security settings configured appropriately:
http://krpano.com/docu/localusage/#top
Please help me out!
Thank you
The orientation of the embedded video depends on the order you draw the rectangular hotspot corners, you normally need to start top left and proceed clockwise.
eacapture
by eacapture » Wed Mar 13, 2013 8:50 pm
Many thanks for the answers! It help a lot.
Georg, so i´ll wai for the panotour pro 2.0. I try use Bing maps and don´t work too.
Akphoto, i´ll try to put the project on line. The Flash security is configured appropriately.
Mediavets, i´m very happy with your tip about the video! That was it.
And i try to use Bing Maps too, and still is not showing up. The The Flash security is configured appropriately
Thank you all, one more time!
by gkaefer » Wed Mar 13, 2013 9:13 pm
eacapture wrote:Many thanks for the answers! It help a lot.
if you use ptp 1.8 than a krpano license is embedded you can Export. so you than can now use the krpano package which does have more modern map supports (allthow some of the plugins there are to pay for seperately) also Google maps...
... so no Need to wait for panotour 2.0 (which many of us are waiting since last photokina and earlier ;-))
