Desaturated Colours
christa
Desaturated Colours
by christa » Mon Feb 18, 2013 9:10 am
Hi, I'm new to this forum so forgive me if this topic has been discussed before. I did do a search but nothing came up. I've recently purchased the Panotour Pro and finding my ways around it. Noticed that once a tour had been built the colours when viewing as a swf file are somewhat desaturated compared to the original panorama when viewed in photoshop or in the pano tool. Any ideas? Thank you.
Christa
christa
by christa » Tue Feb 19, 2013 11:17 am
Am I really the only one with this problem?
Christa
by klausesser » Tue Feb 19, 2013 12:14 pm
christa wrote:Am I really the only one with this problem?
Christa
Which profile are you using in your equirectangular images? If you use Adobe1998 you´ll find the colors desaturated
in browsers. For that reason either don´t use any profile or use sRGB.
christa
by christa » Tue Feb 19, 2013 8:29 pm
Thank you so much for geting back to me Klaus. You're very generous with your expertise I've noticed. Excuse my ignorance but where do you set the profile. I'm using PTGui.
Kind regards.
Christa
by klausesser » Tue Feb 19, 2013 9:36 pm
christa wrote:Thank you so much for geting back to me Klaus. You're very generous with your expertise I've noticed. Excuse my ignorance but where do you set the profile. I'm using PTGui.
Kind regards.
Christa
Hey Christa!
You can set the profile easily in Photoshop - guess you check the equi-image anyway in PS after rendering!?
christa
by christa » Wed Feb 20, 2013 8:51 am
Thanks again Klaus. Yes I do check in PS. Colour profile set to sRGB and Proof Setup to Monitor RGB/Proof Colors checked so what I see on screen is pretty much what I should get when saving image. But as I said, when viewing as swf file colours are muted??
Christa
ade123321
Re: Desaturated Colours
by ade123321 » Tue Oct 29, 2013 4:24 pm
6month old thread but ill post anyway!
this is the first thing I noticed when doing my first tour.
ade123321
by ade123321 » Tue Oct 29, 2013 11:11 pm
yes Klaus is right (of course!) newbs beware! or you'll have this....
turn into this....
convert properly to srgb!
thank you Klaus.
