full screen output
fuxco
full screen output
by fuxco » Mon Feb 04, 2013 11:01 am
hi
I want when start swf export , this open in full screen mode ,
this mean I dont what project open een 1024*768 px ,
I want open my project een fullscreen mode in all of devices in default view,
program don't have this option , :(
I give a exe export with project creator in flash player . but this export againe dosen't open in full screen mode .
expect of use SWF MAESTO EXE PRO , there have any way ?
this is very important and force for me ,
My time is very limited for resolve this problem ,
thank you
by Destiny » Mon Feb 04, 2013 11:04 am
Hi..
Follow this.. and it will work fine...
fuxco
by fuxco » Mon Feb 04, 2013 12:00 pm
hi again
no this option work in swf and html mode. in other wise this method work for html viw in web situation
I want have export for cd ( multi media and use autorun.inf file.and this mean I should in one step change swf to exe file (with flash player exe creator project) and then run in fulscreen mode.
what have a way for this operation?
fuxco
by fuxco » Mon Feb 04, 2013 12:01 pm
I want open project without flashplayer in other system
by klausesser » Mon Feb 04, 2013 12:07 pm
fuxco wrote:I want open project without flashplayer in other system
The Flash-Player rules prohibits to START an .swf as fullscreen. You need to do it via html.
fuxco
by fuxco » Mon Feb 04, 2013 12:15 pm
no , if change swf to exe , other system don't need to install flash player.
i want open exe file in full screen mode by default,
this work do very well with SWF MAESTRO EXE ( swf to exe programs) but I want do this work without this program , I find follow way to do this operation with panotour pro
by mediavets » Mon Feb 04, 2013 12:36 pm
fuxco wrote:no , if change swf to exe , other system don't need to install flash player.
I believe you can create standalone EXE using the krpano kprotect tool:
http://krpano.com/tools/kprotect/
by klausesser » Mon Feb 04, 2013 12:57 pm
Well - nevertheless:
.swf needs Flash. The security guidelines of Flash don´t allow to start as fullscreen.
That´s what Adobe says. And indeed it doesn´t work.
You can start it with a BIG screen - but not as FULL-screen ;)
Maybe .js allows starting as fullscreen - i don´t know.
by gkaefer » Mon Feb 04, 2013 1:25 pm
the option "start in fullscreen" when exporting to exe does exist..
... and does open in fullscreen (without any browser so no flashplugin restrictions in this case)
fuxco
by fuxco » Mon Feb 04, 2013 1:27 pm
thank you
how I can download krpano kprotect tool ?
this page dont exist any link for download this program .
please download link.
by gkaefer » Mon Feb 04, 2013 1:35 pm
http://www.krpano.com/download/
krpano Tools
PS: from ptp 1.8 you can export the krpano licenses... so download the krpano Tools zip file, extract it and than export the krpano licenses to this directory. starting the "krpano Protect Tool.exe" (windows name) than will automatically find the licenses....
fuxco
by fuxco » Mon Feb 04, 2013 4:42 pm
thanx
I can downlowd this tool and run with panotour pro ,
but when I add swf file in "embedding" tab and clicked in Generate protectet file , program give this error : "not startup xmf file selected"
when I export my tour by ptp don't have a xml file .
please help me .
fuxco
by fuxco » Mon Feb 04, 2013 4:52 pm
when iI exporting my project iin ptp , I select "embed all data" option , when selected this option progrms build only onw swf file and one folder which in than is movie and sound , but not exist any xml file ,
please help , I don't have XML file when export with embede all data mode.
by gkaefer » Mon Feb 04, 2013 5:40 pm
fuxco wrote:when iI exporting my project iin ptp , I select "embed all data" option , when selected this option progrms build only onw swf file and one folder which in than is movie and sound , but not exist any xml file ,
and what could be the solution? 1 - 1000 - 2 - 1000.... bingo: deselect the "embed all data" and let ptp 1.8 create the xml files - yes its real that simple. :cool:
after you created these non-embedded files you run the krpano protect ... to embed the complete files and subfolder pack to one exe file.
fuxco
by fuxco » Mon Feb 04, 2013 6:41 pm
all right ! but I want all pictures and logos and etc in one swf file , because other users can not remove my logo and change my logo with theirs logo!
I finding solution witch create one .exe file and ond one dataproject folder ( in this folder only exist films and sounds without map & logo & etc pictures )
by mediavets » Mon Feb 04, 2013 6:47 pm
fuxco wrote:all right ! but I want all pictures and logos and etc in one swf file , because other users can not remove my logo and change my logo with theirs logo!
I thought you were trying to create a single EXE file?
For a person seeking advice you seem remarkably unwilling to accept it when offered. :rolleyes:
fuxco
by fuxco » Mon Feb 04, 2013 7:19 pm
no no , i want have an output with one exe file and one folder which in there are only movie and sound , because my project consisted 2.5 gig movie and sound in hotspot , only i want users could't change my logo or help pictures with theirs logo and named my project to theirs.
i need Exactly same output witch program build in "embed all date" options .
by gkaefer » Mon Feb 04, 2013 9:22 pm
if I reread your whishlist from first to last topic I conclude you more than once turned your opinion for 180 degree.
embedd to swf
all in a exe
on all devices starting in fullscreen
protection of your logo and other parts of your tour by embedding, but at same time including 2.5Gig videos to the tour without embedding.
that does not work.
you've to make clear what you want to present in which media to which audience.
take the fullscreen.html template and embedd your tour. videos get not included with this method. the fullscreeen.html has an builtin switch mobile devices get an HTML5 and all others get an SWF tour presented.
tour will be started with default browser in fullscreen, but not browserless mode (the fullscreen button in the navbar of your tour). thats by flash limitations not possible to access directly.
This all can be put on a CD and started with an autorun.ini (on modern PCs is in general the autostart feature disabled by default, so this plan will not work anyway). If you wanna have influence on more output devices, than dont embedd the xml files, and add according to krpano documentation more switches for other devices (android mobiles, android, tablets, ipads with or without retina, whatever)
PS: if you wanna distribute your tour on CD as mentioned, why fearing any changing of your data? its on a CD... cant be changed...
fuxco
by fuxco » Tue Feb 05, 2013 7:03 am
very thanks my friend , I think my problem is solved in best status with your guidance.
I got what I wanted ,
very thanks.
gkaefer wrote:if I reread your whishlist from first to last topic I conclude you more than once turned your opinion for 180 degree.
embedd to swf
all in a exe
that does not work.
by mediavets » Tue Feb 05, 2013 9:59 am
fuxco wrote:very thanks my friend , I think my problem is solved in best status with your guidance.
I got what I wanted , very thanks.
What solution did you chose in the end?
by klausesser » Tue Feb 05, 2013 1:09 pm
gkaefer wrote:take the fullscreen.html template and embedd your tour.
That´s what i meant when i suggested to do it via html. You open a fullscreen html window then in which the pano runs fullscreen - you do not open an .swf on start as fullscreen (though it looks like it) . . :cool:
fuxco
by fuxco » Tue Feb 05, 2013 4:22 pm
no best status for create an exe file in full screen mode to use in multi media cds is using "krpano kprotect tool"
with this programs , you can embed all file by interesting idea .
1) export your project in ptp without select check box of "embed all data and embed xml fiile"
2) open krpano kprotect tool and add xml file and all files you interesting too add on final exe file ( I add my logo and my map and my pictues without movies and sounds)
3) generate final exe project and enjoy.
full screen status with .html is nice for online preview and not usefull for create exe file for multimedia cds.
have a good time
thanks
by gkaefer » Tue Feb 05, 2013 5:59 pm
fuxco wrote:no best status for create an exe file in full screen mode to use in multi media cds is using "krpano kprotect tool"
have a good time
thanks
this makes no sense. 1) and 2) contradict. if you 1) embedd all and embed xml files than you get no xml files for 2)
why do you persist on must having an exe file if you use a CD media for distribution?
(and if you try the protect tool with bigger tours, not only a 8image fisheye pano, but lets say 10 panos with 20-100 images each than you will sadly notice that it can be very annoying to open such tours from CD media. 1min + waiting time is not the best marketing feature...)
by klausesser » Tue Feb 05, 2013 6:13 pm
gkaefer wrote:this makes no sense. 1) and 2) contradict. if you 1) embedd all and embed xml files than you get no xml files for 2)
:D:cool:
fuxco
by fuxco » Tue Feb 05, 2013 6:18 pm
My project have 72 panorama pictures which they are linke to another . ( over 2000 hotspot point ) + over than 2.5 GB movies and sound ,
if i don't add separated pano images to embed in one exe file , and open separated image of panos from data folder in side of exe file , do it is smaller size ?
How i can increase load speed time on dvd ?
do not embed image in one exe file or embed image on that ?
