alosurdo wrote:i should also add, i can see the hotspot move around in the maps section, however no map when i open the HTML file locally? Does it need to be uploaded to a server for some reason to see the maps?? it would be great if it didnt just so it could be tested locally.
Thanks in advance
Thanks in advance
Christian Stüben wrote:When you create the key, you have to enter a website name.
And when starting the map inside you panotour, Bing maps tries to check if the key is correct. This cannot be done on a local server or on your development pc.
So your panotour must be placed on a public website ( [text]http://yourpublicwebsite.xyz[/text] ) to see more than white space.
greetings from Wuppertal
Chris
