Panotour compatibility with android 4.1
hermer-blr
by hermer-blr » Mon Dec 10, 2012 10:37 pm
I just noted that Android 4.1 does not support Adobe Flash Player. What about the compatilbility of Panotour and Panotour Pro with Android 4.1 ?
My understanding is that Krpano is embedded in Panotour; KRPANO exists in 2 different versions: Flash and HTML. Which one does Panotour handle ?
Thank you
Windows 32 bits - APG
website htt://jmh.trp.free.fr
by mediavets » Mon Dec 10, 2012 11:15 pm
hermer-blr wrote:I just noted that Android 4.1 does not support Adobe Flash Player. What about the compatilbility of Panotour and Panotour Pro with Android 4.1 ?
Things may have changed biut last time I checked this out on the krpano site forum, Android 4.1 didn't provide proper support for Flash panoramas/tours nor for HTML/javascript panoramas/tours. This is a Google/Android issue not a krpano/Panotour issue.
See: http://krpano.com/docu/html5/
Panotour can only build tours for Flash.
Panotour Pro can build tours for both Flash and HTML/javascript.
In both cases you need no additional licenses.
You can export the embedded krpano license from Panotour Pro and use it separately with krpanotools if you wish.
You cannot export the embedded krpano license from Panotour.
