Top Logos not showing
AH360
by AH360 » Mon Jun 25, 2012 11:32 am
Hi everybody,
Recently, I´m having trouble getting the TOP RIGHT/LEFT Logo inside my VR.
I don´t what could be wrong, because I allready use that before, with the same size and same format (PNG).
Here is an exemple with sucess:
http://www.ah360graus.com/tour/Queen_Anne/360.html
And after that, every VR that I do, I can´t get the TOP logo anymore, as seen here:
http://www.ah360graus.com/tour/Towers_Hotel/360.html
Someone here allready had that kind of issues and know how to fix it?
by mediavets » Mon Jun 25, 2012 11:53 am
Welcome to the forum...
Do you see any difference in the XML code relating to logos between the two tours?
Likes: 14 posts
by bdd » Mon Jun 25, 2012 11:55 am
In the second tour, is the lacking logo this one : http://www.ah360graus.com/tour/Towers_Hotel/360data/graphics/logo3.png ?
This logo seems to be loaded by the tour, but it is not displayed.
Did you set a height and/or a width to this logo in Panotour Pro ?
AH360
by AH360 » Mon Jun 25, 2012 12:15 pm
I set the width, to 100px. I have to set both, width and height?
AH360
by AH360 » Mon Jun 25, 2012 12:17 pm
Thanks for the welcome mediavets,
I´m not an expert with XML... could you give me some tips where to start looking?
by mediavets » Mon Jun 25, 2012 12:27 pm
AH360 wrote:Thanks for the welcome mediavets,
Look for the Logos section in the main xml file - for each tour there's a main xml file, then an xml file with a numerical suffix for each pano scene - screenshot 1.
You can easily locate the xml files (and orther files comprising the tour) using the Edit/Open last exported project directory command - screenshot 2.
by mediavets » Mon Jun 25, 2012 12:30 pm
AH360 wrote:I set the width, to 100px. I have to set both, width and height?
No, you do not need to set values for both height and width.
If you leave one of these values at '0' (zero) then it will automatically maintain the aspect ratio of the logo image.
AH360
by AH360 » Mon Jun 25, 2012 6:52 pm
Hi mediavets,
I found the main XML file and found the problem... this is what I got there:
<plugin name="logo3" url="builddata/graphics/logo3.png" keep="true" align="lefttop" x="20" y="20" width="50" height="-10823542" handcursor="false" capture="false"/>
I changed the height value for "prop" and the logo show up.
What I did to this height get this strange number?
Anyway, thanks... save my life!
Likes: 14 posts
by bdd » Tue Jun 26, 2012 7:21 am
Did you changed your project file (the *.kpt file) since the moment you found this bug ?
If you did not change it, then can you send it to kolor at contact[ at ]kolor.com ?
We "already" fixed this bug, but maybe we did not fix all the cases were such strange values appear.
I re-open the issue concerning this bug.
AH360
by AH360 » Tue Jun 26, 2012 12:27 pm
Hi Gérald,
I sent you the .kpt file, check your mail inbox.
